Head Gasket ?
Old Feb 7, 2005 | 02:46 PM
EKIM NART's Avatar
Default Head Gasket ?
Where can i find a oversized head gasket for my ls-vtec. the reason why i need os head gasket is because the block needed to be bored. the ls motor sat up for awhile and water got into the block and locked up. the #1 cylinder got scarred pretty bad and i went ahead and bored it to fit os itr pistons. thanks
Old Feb 7, 2005 | 04:07 PM
chameleon's Avatar
Default Re: Head Gasket ? (Ef2Ls)
cometic, GE, etc
Old Feb 7, 2005 | 05:58 PM
EKIM NART's Avatar
Default Re: Head Gasket ? (chameleon)
thanks for the reply
Old Feb 9, 2005 | 03:40 AM
NJIN BUILDR's Avatar
If your still under 82mm (plus 1.0mm) you can still use the stock gasket.
Glenn
Old Feb 9, 2005 | 06:31 AM
X-Mazda 3 Racer's Avatar
Default Re: Head Gasket ? (NJIN BUILDR)
Our gaskets also have the dowel hole opened up for ease of installation.
Old Feb 9, 2005 | 06:53 AM
EliteCivicX's Avatar
Default Re: Head Gasket ? (GoldenEagleMfg.com)
http://www.summitracing.com
where i got a good head gasket
PhatBoy5015
Jun 19, 2006 12:44 PM
JLHDOHC
Feb 12, 2006 08:44 PM
reek
May 3, 2005 01:38 PM
Speed PHreak
Nov 20, 2002 08:00 AM
