VSS out of a SOHC in a F22
i know you can use a sohc vss in an h22 tranny so im sure it will work. Now what your gonna want to make sure is that the mounting holes line up right. I mention the mounting holes because i have already done a test fit from a 1994 civic vss on a 92-96 h22 tranny. the casing is different and the mounting holes dont line up. You will have to shave some of the vss off ans also use a washer to hold the vss down.
lsturboguy
Aug 23, 2008 06:08 PM
vitrox
Jul 9, 2004 02:44 PM
