engine won't start...NEED HELP PLEASE!!!
Old Feb 7, 2005 | 12:20 PM
solk1dd's Avatar
Default engine won't start...NEED HELP PLEASE!!!
i took off the wire that connects to the starter from the battery. i accidently hit a metal and it sparked. now my car won't start. it cranks, but doesn't start. i changed the starter, still doesn't start. changed the distributor, still doesn't start. checked all my fuses, still doesn't start. changed my spark plugs and wires, still won't start. WHAT ELSE COULD IT BE? ??
Old Feb 7, 2005 | 12:22 PM
jlacoy82's Avatar
71.192.16.183
Default Re: engine won't start...NEED HELP PLEASE!!! (solk1dd)
Does your fuel pump prime?
Did you check all fuses under the hood as well as under the dash?
Old Feb 7, 2005 | 12:30 PM
solk1dd's Avatar
Default Re: engine won't start...NEED HELP PLEASE!!! (jlacoy82)
what does "prime" mean?
Old Feb 7, 2005 | 12:31 PM
AllmtrSlut's Avatar
thats wierd, might have shorted some ****. But it sounds like u not geting spark to me.
Old Feb 7, 2005 | 12:33 PM
solk1dd's Avatar
Default Re: engine won't start...NEED HELP PLEASE!!! (AllmtrSlut)
i changed my distributor and spark plugs and wires
Old Feb 7, 2005 | 12:34 PM
jlacoy82's Avatar
71.192.16.183
Turn your key one click before the car starts to crank and listen for the fuel pump/relay to "click" and you'll hear it hum for a few seconds. The sound will come from below the rear seat cushion.
Old Feb 7, 2005 | 12:35 PM
solk1dd's Avatar
yes it does "prime"...i did that a couple times...still won't start
Old Feb 7, 2005 | 01:09 PM
sammysnakes's Avatar
double check all your fuses, under the dash and under the hood.
Old Feb 7, 2005 | 01:17 PM
civicboisi's Avatar
Default Re: (sammysnakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solk1dd &raquo;</TD></TR><TR><TD CLASS="quote">i took off the wire that connects to the starter from the battery. i accidently hit a metal and it sparked. now my car won't start. it cranks, but doesn't start. i changed the starter, still doesn't start. changed the distributor, still doesn't start. checked all my fuses, still doesn't start. changed my spark plugs and wires, still won't start. WHAT ELSE COULD IT BE? ?? </TD></TR></TABLE>
exactually WHAT metal did you come in contact with?
Old Feb 7, 2005 | 01:21 PM
AutoXer's Avatar
Default Re: (civicboisi)
Spark = most likely a short.
Check and re-check your fuses. Did you check your fuses in the engine bay as well?
Old Feb 7, 2005 | 01:40 PM
solk1dd's Avatar
Default Re: (EX_AutoXer)
checked ALL fuses
Old Feb 7, 2005 | 01:42 PM
jlacoy82's Avatar
71.192.16.183
Default Re: (solk1dd)
By checking you mean you pulled every single one out and inspected visually/used a test light on them? Or by checked everyone you mean you just looked at them and figured they were good?
Test light/meter &gt; any amount of eye-balling you can do.
Old Feb 7, 2005 | 01:44 PM
SOHCD16y8's Avatar
Default Re: (jlacoy82)
swap in a friends ECU quick, i could have fried
Old Feb 7, 2005 | 01:46 PM
solk1dd's Avatar
used a fuse test light on each one and did a visual check
Old Feb 7, 2005 | 01:47 PM
solk1dd's Avatar
Default Re: (SOHCD16y8)
i'll try that
Old Feb 7, 2005 | 01:50 PM
chrisknight's Avatar
Damn... I had that happen once... Changing the starter and touched the wire to the starter case... Woops!!!
OK, your fuel pump is working...
Take one spark plug out plug it back in to the wire and somehow touch the spark plug threads to the engine block (wrap wire or something) have someone look at it while you tap the starter with your key to see of you have spark. Dont hold the plug to test... It will hurt you! hehe...
If you got spark, start checking the fuses with a multi-metre. Sometimes they dont blow black and its hard to see..
You should have continuity through all of your fuses... Of you have an Ohm metre, you will see a dead short on em... Open means its bad... Check the box under the steering wheel and the box under your hood...
Did you check relays?
CaseyB
Nov 16, 2012 06:03 AM
bmxbikes
22
Jul 4, 2007 07:23 PM
slow_redcivic
10
Apr 9, 2006 04:57 PM
civic efb16
Aug 8, 2005 09:00 PM
same ol' civic
Jun 5, 2005 07:29 AM
