timing belts seals question
I am doing a timing belt change on my 94 accord LX-R, and am trying to prepare for it before hand. I have never done this on a Honda. I plan on changing the 4 seals, cam, crank, and both balancers seals. My question is how do you replace each of these. The helms manual doesn’t seem to say much about this step. I also have the retainer plate in case my car doesn’t have one yet.
Also, what is the best technique to set the engine at TDC?
Also, which directions do I turn the engine when I am tensioning the belts with the adjuster nut both loose and tight?
Thanks.
Thanks.
Here's a link
http://www.cybertrails.com/~be....html
Another link, My favorite
Shows crankseal removal
http://members.troublecodes.ne...e.htm
You might also search this website, there is probably a few hundred posts that will answer your questions
Shows crankseal removal http://members.troublecodes.ne...e.htm
Be prepared for the crank pully to be a MF to ge off. Also read in the Helms manual in the engien tear down section it will tell you how to replac the seals.
hey man
13
Nov 15, 2010 06:57 PM
nightime25
Feb 22, 2009 05:09 PM
