Wheres the tach output on my h22 4th gen?
Old Feb 7, 2005 | 10:20 AM
dmxsoulja3's Avatar
Default Wheres the tach output on my h22 4th gen?
I just got a tiny shift light, http://www.raptorperformance.com/
Dimensions: 3.125" x 0.75"!!!!
And I'm not sure I have ever seen someone mention where the tach ouput wire is.
Thanks, Josh
Old Feb 7, 2005 | 10:30 AM
Greyout's Avatar
Default Re: Wheres the tach output on my h22 4th gen? (dmxsoulja3)
I used the service connector.
If you pop the hood, there is a single blue wire w/ a simple plug tied down between the fuse box and where the stock airbox would be, on the inside of the wheel well. The dealer uses this as a tach source for their diagnostic stuff. I cut the plug off & used that.
Old Feb 7, 2005 | 05:02 PM
PrettyLude's Avatar
Default Re: Wheres the tach output on my h22 4th gen? (Greyout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greyout &raquo;</TD></TR><TR><TD CLASS="quote">I used the service connector.
If you pop the hood, there is a single blue wire w/ a simple plug tied down between the fuse box and where the stock airbox would be, on the inside of the wheel well. The dealer uses this as a tach source for their diagnostic stuff. I cut the plug off & used that.</TD></TR></TABLE>
E.F.Honda
Apr 24, 2008 05:07 AM
4dooreg-k
11
Jun 23, 2006 12:50 PM
hatchfreak92
Oct 19, 2004 08:57 AM
fitbmx86
Jan 28, 2004 05:48 PM
yusoslo
Feb 22, 2003 07:05 PM
