trying to drain coolant..
I am trying to remove the 19mm bolt on the block to drain the coolant on the engine..
i cant get that freaking thing out.. where can i find a "breaker bar"?
i am using a pretty long bar right now, the wastegate kind of gets in the way but i dont want to take that off because its probably not going to help that much anyway
any other suggestions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j boy »</TD></TR><TR><TD CLASS="quote">this is what i am trying to get too, just to give you an idea
picture is courtesy of team-integra</TD></TR></TABLE>
Lol I just sat there staring at that pic for like 3 mins thinking "where the **** is this wastegate he's talking about"...I say go ask neighbors or maybe goto a local shop and see if you can leave something thats worth something in exchange for borrowing their breaker bar until you return it...
I always have trouble getting the bolt off when changing my oil. I just put the correct size wrench, make sure its snug, and bang it with a hammer. works every time. have you tryed that? be careful not to strip it if u do.
I would just go buy a breaker bar if I were you... they aren't that expensive and they come in handy really often if you are working on old Hondas...
You should be able to break that loose easily with a breaker bar...
If none of your exhaust manifold tubing is in the way, try using a 6 or 12" (probably 12") 1/2" extension (like $10 if that) and a 1/2" breaker bar ($20-30 dollars I believe for a Craftsmen) so you have room out by the radiator support to turn the breaker bar. If you do manage to break it loose, slap a ratchet on there and go to town.
Good work, U could have also use some wd-40
But just to let you know the longer the handle the more ft-lbs you put on that bolt.
so a 1 ft handle putting on a 10lb pressure is 10lbs-ft.
and another 1ft to equal 2 ft. put on the same 10lbs of pressure and in actuallity you are putting down 20lbs. of pressure, woo hoo!! it is physics... all the way.
handle length || Your strength||equals
1ft X 10lbs = 10lbs-ft
Handle length plus added length || You strength||Equals
(1ft+1ft) X 10lbs = 20lbs-ft
Simple math, huh!?
Simple math, huh!?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">
Lowes breaker bar = a few feet of steel piping?
exactly, i just bought a huge pipe that fit on the end of my ratchet, worked like a charm
</TD></TR></TABLE>exactly, i just bought a huge pipe that fit on the end of my ratchet, worked like a charm
