Grinding around 4,000 rpms???
Old Feb 7, 2005 | 08:56 AM
Ryan.'s Avatar
Default Grinding around 4,000 rpms???
I have a 1999 Honda Civic Si and this noise just started the other day. There is a grinding noise right around 4,000rpms. This only happens after vtec has been enganged. For example if v-tech has not been hit yet this noise will not exist. But after hitting v-tech for the first time during that drive it does it everytime the rpms are at 4,000. Any thoughts. Thankyou
Old Feb 7, 2005 | 09:06 AM
Soccerking3000's Avatar
Default Re: Grinding around 4,000 rpms??? (R-starr*)
one of your cams might have a chunk out of it, so when the extra lobe is being used it grinds because it is uneven,i would check them out
Old Feb 7, 2005 | 09:07 AM
Ryan.'s Avatar
Default Re: Grinding around 4,000 rpms??? (Soccerking3000)
thanks for the info bro
Old Feb 7, 2005 | 09:18 AM
Ryan.'s Avatar
Any other thoughts on this problem?
Old Feb 7, 2005 | 10:01 AM
Ryan.'s Avatar
someone help me please
Old Feb 7, 2005 | 10:06 AM
lemansteve's Avatar
i would say its a valvetrain issue, too. a cam with a chunk out of it doesnt seem likely to me, but you never know! what exactly does it sound like?
Old Feb 7, 2005 | 10:34 AM
EG_Civic_Si's Avatar
Default Re: (lemansteve)
I have the same problem, kind of. But i have a stock 94 CX hatch. I just had the clutch replaced and flywheel resurfaced. Whenever i am driving, theres a nasty grinding noise. Sound starts right around 2500 rpms. Sounds horrible in 1st gear. second gear, you can kind of hear it. 3rd very faint, but 4th and 5th, no noise.
Also, If im sitting at a dead stop in neutral, and i dont have the clutch engaged, u can hear grinding, but when i engage the clutch, u can hear something spin around for a second or two then slow down to a stop.
Old Feb 7, 2005 | 10:39 AM
mct121's Avatar
Are you sure the grinding is coming from the head? It may just be something loose (such as a piece of heat shielding on the exhaust) that starts to vibrate when the engine is operating at just the right speed.
Old Feb 7, 2005 | 11:03 AM
Ryan.'s Avatar
Default Re: Grinding around 4,000 rpms??? (mct121)
Yea thats what i was thinking at first. I checked it all but I will check again since I just receantly slammed my car. I have bottomed out a couple of times since then. I will check the exhaust one more time.
Old Feb 7, 2005 | 11:11 AM
Zekers's Avatar
Default Re: (EG_Civic_GSR)
I had the same problem EG_Civic, It turned out to be the main input shaft bearing.
Check it out
https://honda-tech.com/zerothread?id=1123369
Old Feb 7, 2005 | 11:20 AM
Default Re: (Zekers)
Thanks Zekers. gonna get it checked out.
Old Feb 7, 2005 | 03:40 PM
Ryan.'s Avatar
I just had my tranny replaced and all the bearings and seals were replaced also. It cant be that. Any other suggestions?
Old Feb 7, 2005 | 04:09 PM
k24a4kid's Avatar
I'm a Jackass
Default Re: (R-starr*)
then it's not your trans. it's something with the cams ....or it might be vtec just kicking in
haha
Old Feb 7, 2005 | 04:15 PM
Ryan.'s Avatar
Default Re: (turbofienD 04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbofienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">then it's not your trans. it's something with the cams ....or it might be vtec just kicking in
haha </TD></TR></TABLE>
It happens before v-tec. At 4,000rpms.
Old Feb 7, 2005 | 11:04 PM
manekDC2.'s Avatar
haha damm your already smacking face on the street and, you still have some drop left.. damn man i never banged my **** ever.. i guess im too ****, but thats how you have to be if you want a slammed car man.. if you keep hitting **** raise it back up bro.. hitting **** isnt good at all.. thats why fatter tires are better as well they absorb **** more and get better traction.. oh well tho bro, i'll take a look at it soon, if you ever stop being gay and only calling me up when you need something done to your car..
Old Feb 10, 2005 | 04:24 AM
Ryan.'s Avatar
Default Re: (manikgsr)
i need new exhuast dammit
Old Feb 10, 2005 | 11:15 AM
mct121's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-starr* &raquo;</TD></TR><TR><TD CLASS="quote">i need new exhuast dammit </TD></TR></TABLE>
What was the problem?
Old Feb 14, 2005 | 02:05 PM
manekDC2.'s Avatar
Default Re: (mct121)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mct121 &raquo;</TD></TR><TR><TD CLASS="quote">
he thinks too much.. and knows too little.. haha j/k it was his exhaust.. he has a bummy *** one right now and the sound was vibration not grinding.. so when he gets a new one that joint should be good as new y00..
DaveSi677
Nov 4, 2008 07:18 AM
looneytoonz
Nov 10, 2007 06:14 AM
ghettogk
Nov 15, 2004 06:38 AM
typeee
Nov 28, 2002 07:44 PM
