I'd like to send a huge F#$% YOU to my distributor...
Old Feb 6, 2005 | 10:30 PM
Opie's Avatar
Default I'd like to send a huge F#$% YOU to my distributor...
I went out to Brooklyn yesterday to chill with Bbasso. We hung out got some sandwiches watched some TV yada yada. I left around 4 and after about 45 minutes of down town traffic made my way back to the burbs.
2 blocks from my GF's house my CEL came on and my car bogs down. No problem, happens from time to time. Pull over, turn the car off, pop the hood. My J's intake from time to time rubs my plug wires loose of the distributor. Figured it was the same situation this time. I pop the hood and surprisingly everything is in place and connected. ****, now what. Call the GF tell her to bring some sockets so I can get the plug cover off. She shows up and I start pulling all the plugs out one by one to check for spark. All the plugs are fine and I'm firing on all 4 cylinders.
****, now what? The most random things ran thru my head while trying to diagnose it. Since it would still fire up I figured whatever damage that was done was done and I drove it and parked it at my gf's house.
ECU jumping revealed a CEL 9. I was right, dizzy is fugged.
So, today I woke up and got to work. Took the cap off and the problem was plain as day. Ask my friend to half crank the motor so I could get the rotor screw to become exposed to take it off. Cranked it once and a huge empty space appeared. The screw was gone
I removed the rotor and found this
Still no screw in sight. Upon further investigation I found the screw wedged inside the dizzy, stuck to the magnet.
Everything in the dizzy seemed to be okay. The screw had on scraped a tiny bit of the magnet, and since I had a spare cover and rotor screw from my last call to Len I cleaned off whatever shavings were in there and slapped some new pieces in.
New Cover thingy
New Rotor Screw
Put everything pack, connect the battery and start her up. Clean start no problem, then the CEL starts blinking. F$%#&! Mother F@*#@*)!*!!!
Seems as though the minor scraped and gouges from the screw were worse than I thought
So, I did the only thing I could do on a Sunday afternoon when parts is closed,
Tomorrow I'll go to my local dealer, grab a rotor and see if that's the problem. If not, I'll be calling Len for a new dizzy
Old Feb 6, 2005 | 10:51 PM
Dr. EKology's Avatar
Default Re: I'd like to send a huge F#$% YOU to my distributor... (opie)
Argh that bites! Good luck getting her fixed 0pie!
:middlefinger: for your distributor.
<- Who thinks a busted dizzy > busted knee any day of the week.
Old Feb 6, 2005 | 11:02 PM
Bbasso's Avatar
D'OH!
Glad I did not have to perform roadside assistance
Old Feb 6, 2005 | 11:06 PM
Haleiwa-Brando's Avatar
Default Re: I'd like to send a huge F#$% YOU to my distributor... (Bbasso)
**gonna leave Rob hanging here**
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">D'OH!
Glad I did not have to perform roadside assistance </TD></TR></TABLE>
I thought that's what friends are for ROB!
Old Feb 6, 2005 | 11:07 PM
Haha, you got lucky the REAL girlfriend was around.
Old Feb 6, 2005 | 11:11 PM
Trev-R's Avatar
Damn that sucks same thing happened to my friends Si. Hope she gets well soon.
Old Feb 6, 2005 | 11:27 PM
DC2IntegraTypeR's Avatar
Damn you Honda and your cheap distributors! ^^
Old Feb 6, 2005 | 11:29 PM
Dan GSR's Avatar
distributor king is cheaper
aka flying pat on HT
Old Feb 6, 2005 | 11:48 PM
Chris93Si's Avatar
Sucky but glad nothing too major
Old Feb 7, 2005 | 01:14 AM
kidkombo's Avatar
Default Re: I'd like to send a huge F#$% YOU to my distributor... (Chris93Si)
holy ****, believe it or not...that was the same **** that happend to me! the dam screw was stuck in that thing....good luck man, i had to get a new dizzy too my bearing was screwed up...good luck
Old Feb 7, 2005 | 01:49 AM
KayOs's Avatar
Check the resistance of your ignition coil and ignitor while you're in there. Could be one of those components going bad as well.
Old Feb 7, 2005 | 05:16 AM
Batoutahell's Avatar
Default Re: I'd like to send a huge F#$% YOU to my distributor... (Dan GSR)
Not only is Distributor King much cheaper than OEM, they make a better dizzy. I have their dizzy on my R and on my ita crx. They use better bearings than OEM and should be less susceptible to burning out the igniter, which is a weak spot on hondas.
Oh, and DK is also a long-time ITRCA sponsor!
Old Feb 7, 2005 | 05:26 AM
canuckr's Avatar
Default Re: I'd like to send a huge F#$% YOU to my distributor... (KayOs)
Ouch....Mine did the same thing. The same screw came out and killed the cap, rotor, and a component inside. Ended up getting a new distributor from Distributor King, it has been running good for the last 2 years...
Old Feb 7, 2005 | 05:29 AM
slackeR1366's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">distributor king is cheaper and better than OEM
Old Feb 7, 2005 | 05:47 AM
DutchITR1689's Avatar
That rotor screw got loose in 80% of the ITR engines I have seen...
Old Feb 7, 2005 | 05:55 AM
RTW DC2R's Avatar
damn y0pie! atleast its an easy fix, just a pain in the ***.
Old Feb 7, 2005 | 06:20 AM
Jon D's Avatar
all will be well kidd....
as discussed on the phone, **** coulda been worse!
Old Feb 7, 2005 | 06:21 AM
1115R's Avatar
u got pwn3D!! yea alot of hondas do that my crx did it 2 times and my friends crx has done it as well.
nothing a lil lock tight cant fix!!!
Old Feb 7, 2005 | 06:42 AM
Black R's Avatar
25 Year Member
Default Re: I'd like to send a huge F#$% YOU to my distributor... (DutchITR1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchITR1689 &raquo;</TD></TR><TR><TD CLASS="quote">That rotor screw got loose in 80% of the ITR engines I have seen...</TD></TR></TABLE>
Yup, it's a well known fact that the rotor screw = t3h svck!
Old Feb 7, 2005 | 06:48 AM
BudMan's Avatar
Default Re: I'd like to send a huge F#$% YOU to my distributor... (Batoutahell)
http://www.andale.com/stores/s...rking
Tell Sylvain I sent you from ITRCA.com
He'll be nice to you. I'll be pimpin some new Distributor King goodies (not for sale yet) at the expo!
I've been running their regular distributor for ~2.5 years now, which includes the last 2 expos.
Old Feb 7, 2005 | 07:11 AM
.RJ's Avatar
.RJ
Blue loctite ownz j00
Old Feb 7, 2005 | 07:13 AM
Flux's Avatar
Default Re: I'd like to send a huge F#$% YOU to my distributor... (.RJ)
After stories like this I'm glad I replaced the cp and rotor last week...
Old Feb 7, 2005 | 07:16 AM
totsie7944's Avatar
yea that sucks dude. Hope this isn't gonna cost you too much money. I might be looking to replace my "dizzy" soon to cause its making some noise while the engine is warming up.
Old Feb 7, 2005 | 07:18 AM
cryptikman's Avatar
Default Re: I'd like to send a huge F#$% YOU to my distributor... (BudMan)
I apologize for my ignorance, but why does the rotor screw just come off?
Old Feb 7, 2005 | 07:22 AM
b19coupe's Avatar
Same thing happened to Tbone on his now legendary motor. When I changed my cap and rotor during routine maintenance on the ITR, the rotor screw was loose and ready to fall out
