Where do you hook up your air/fuel gauge power line in your prelude?
Old Feb 6, 2005 | 07:34 PM
btrim23's Avatar
Default Where do you hook up your air/fuel gauge power line in your prelude?
As stated, where do you connect your air/fuel gauge power line inside your prelude (92-96)? Or where to hook it up anywhere so your air fuel gauge will work?
Old Feb 6, 2005 | 08:43 PM
dmxsoulja3's Avatar
Default Re: Where do you hook up your air/fuel gauge power line in your prelude? (btrim23)
white wire on the ECU it would be the plug closest to you when you pull back the carpet and look at the ECU.
Old Feb 6, 2005 | 09:20 PM
The Phil's Avatar
signal line would be the white wire on the ecu
power line, so the gauge has power when the car is on...i'd tap off of your cigarette lighter so you only get power when you're in ACC or ON mode
preludefien
Dec 13, 2006 03:31 PM
prelude1911
Sep 28, 2005 07:24 AM
blacksh
Sep 30, 2003 11:50 AM
