Help! Question about ATTS?
I am thinking about buying 15X6.5 wheels for my 2001 Type SH and I have heard about problems with the ATTS when installing different size and weight wheels. I just purchased the car and I'm not real familiar with the ATTS system so if anyone can drop me a line or two about it i would greatly appreciate it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white_jdm21 »</TD></TR><TR><TD CLASS="quote">I am thinking about buying 15X6.5 wheels for my 2001 Type SH and I have heard about problems with the ATTS when installing different size and weight wheels. I just purchased the car and I'm not real familiar with the ATTS system so if anyone can drop me a line or two about it i would greatly appreciate it!
I just bought some 16x7 Rota slipstreams with the same size tires and I haven't had any problems at all. Ive never heard that you would have problems with differnt size tires and I doubt you would.
</TD></TR></TABLE>I just bought some 16x7 Rota slipstreams with the same size tires and I haven't had any problems at all. Ive never heard that you would have problems with differnt size tires and I doubt you would.
as long as you have the same size wheel all around it will not trip the ATTS light. The only time that different sized wheels trip the ATTS light is when you have one or two wheels that are different sizes.
For example: both rears 16in-both fronts have 15in=ATTS light
both rears 16in-one front 16in one front 15in=ATTS light
both rears 16in(or same size)-both front 16in(or same size)=no ATTS light
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gerhard_001 »</TD></TR><TR><TD CLASS="quote">as long as you have the same size wheel all around it will not trip the ATTS light. The only time that different sized wheels trip the ATTS light is when you have one or two wheels that are different sizes.
I'm with this guy.
Just make sure all four corners are the same height if you're dropped. Play around with it, ATTS is sensitive. Reset the ECU and fix the problem is the ATTS light comes on.
I'm with this guy.
