How do I wire these injectors??
Old Feb 6, 2005 | 06:48 PM
Buck99Si's Avatar
Default How do I wire these injectors??
Well, I have some 440 RC's and I'm confused on the install. The factory plugs won't fit the RC's but they each came w/ a harness and clip plug. Do I need a conversion harness to fit the two together or do I cut the factory plugs and splice the harness that came w/ the RC's??
Thanks!
Old Feb 6, 2005 | 06:56 PM
primeredbeast's Avatar
Default Re: How do I wire these injectors?? (Buck99Si)
are your injectors peak and hold or saturated if they are peak and hold you need to also wire in a resistor box
Old Feb 6, 2005 | 07:03 PM
Buck99Si's Avatar
They are saturated. So I do need to hard wire in the RC harness??
Old Feb 6, 2005 | 07:22 PM
Default Re: (Buck99Si)
replied to your pm man
lonely_driver4
Jan 31, 2019 07:46 AM
tigueremalo
May 11, 2006 11:52 AM
Sleepin'
Jan 31, 2003 02:03 PM
