SPITTING OUT 2ND GEAR
Old Feb 6, 2005 | 04:58 PM
01_S2k_Driver's Avatar
Default SPITTING OUT 2ND GEAR
IS their anyone out their that maybe able to tell me why my second gear is is pushing out when i drive and shift into second the gear doesn't do it all the tiime it only does it a few times but it gets anyoying so please if you have had this expierience tell me what i can do thanks
*what could it be
*what can i do
****************thanks again********************
Old Feb 6, 2005 | 05:56 PM
revlimitx04's Avatar
Default Re: SPITTING OUT 2ND GEAR (98EG)
Could be low on fluid, or bad transmission, or mayb the clutch
Old Feb 6, 2005 | 07:51 PM
AndyD's Avatar
I think it is a bad clutch.
Old Feb 6, 2005 | 08:10 PM
2point6's Avatar
Default Re: SPITTING OUT 2ND GEAR (AndyD)
Check the fluid level. If the tranny was run low on fluid, The shift selector detent rings could have been worn to the point they don't hold the selector in place. Also if a needle bearing has gone bad due to the lack of fluid can also present this problem. Hopefully the tranny is just low and a top off will fix it. I'll keep my fingers crossed for you.
Old Feb 6, 2005 | 11:27 PM
Lakeshow23's Avatar
Default Re: SPITTING OUT 2ND GEAR (2point6)
Check the shifter cables! Damn. They could be out of adjustment, hence the spitting out of gear. Start easy first.
Old Feb 7, 2005 | 04:23 AM
Dougs96SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">I think it is a bad clutch.</TD></TR></TABLE>
I agree
itr1244
Sep 29, 2014 12:52 PM
DC5Danny
Jan 21, 2008 08:36 AM
The Phil
Mar 18, 2005 08:27 AM
elevatethis
41
Nov 24, 2003 12:02 AM
tyflip2
10
Nov 14, 2003 11:49 PM
