1994 Accord EX Ideas and Suggestions.
Old Feb 6, 2005 | 04:50 PM
antibact3rial's Avatar
Default 1994 Accord EX Ideas and Suggestions.
I just recently acquired a 1994 Accord EX w/ 136,000 miles. Was curious as to what I can and should do with it. I care more about performance than appearance. If anyone could give some suggestions, I did look around the forums and gained some ideas, but aside from struts/sway bars, I'm pretty blank in the idea section.
Thank You.
Old Feb 6, 2005 | 05:02 PM
WesQ's Avatar
Default Re: 1994 Accord EX Ideas and Suggestions. (antibact3rial)
Upgrade your suspension first, then brakes. After that look into an H22a swap. Don't do bs to the exterior, don't even get rims, keep the stock 15"s. Lots of info just search.
Old Feb 7, 2005 | 01:16 PM
hondaracin24's Avatar
Default Re: 1994 Accord EX Ideas and Suggestions. (WesK24)
You can get rims as long as there not 19" and heavy as hell. 16" with some nice tires and the car lowered would look good....
Old Feb 7, 2005 | 01:27 PM
jakeiscool's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WesK24 &raquo;</TD></TR><TR><TD CLASS="quote">Upgrade your suspension first, then brakes. After that look into an H22a swap. Don't do bs to the exterior, don't even get rims, keep the stock 15"s. Lots of info just search. </TD></TR></TABLE>
H&R Sport Spring with Kyb Gr-2 gas shocks, goldline camber kit. H22 swap. Some nice tires.
Old Feb 7, 2005 | 01:42 PM
numbinside's Avatar
Default Re: 1994 Accord EX Ideas and Suggestions. (JakeIsCool)
turbo the f22.... will own a h22
Old Feb 7, 2005 | 03:01 PM
cd6SiR
Guest
Posts: n/a
I just bought my 94 ex on Feb 4th. My h22a will be here on the 11th. Ordering some springs and a short shifter then wheels and tires. I am pretty much set for a while after that.
Thats what im doing. But what you should do depends on your funds.
Good luck
jdmCD695
Jun 30, 2008 06:11 AM
90AccordTx
Jun 11, 2005 02:29 AM
r3000
Nov 14, 2004 10:02 PM
S13 slide
Feb 18, 2002 05:45 PM
