Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Tire Help for a newbie?
Old Jan 15, 2002 | 08:48 PM
Missingsohc's Avatar
Default Tire Help for a newbie?
I just got a set 13x5.5 pearl white Mugen CF-48's with a 39 offset. what i need to know is what is the max width tire i can use and how low of an profile should i go on the street. the stock tires where 185/75/13. i was thinking 195/60/13 or close and tell me what you all think about Advan AO32Rs? thanx a mill.
Old Jan 15, 2002 | 08:55 PM
johng's Avatar
Default Re: Tire Help for a newbie? (JDMET-2)
I just got the new 215/50-13 V700's mounted on 13x7 race wheels with a 5" backspace. They fit nice. I think a 215/50-13 would squeeze over that rim if you're looking for meats. The AO32 also comes in that size.
Old Jan 15, 2002 | 09:48 PM
Crack Monkey's Avatar
There isn't much available in 13" sizes any more. The A032R is probably a good bet for a street/track tire in 195/60-13. Tirerack doesn't seem to have anything else close that is streetable (unless you consider 205/60-13 Kumho V700s streetable). Everything else is pretty tame.
Old Jan 15, 2002 | 09:51 PM
getfast's Avatar
185's are OEM on many 5.5" wheels. 195's will fit on 5.5's just fine also. 205's will fit with some sidewall bulge. Not sure if 215's are a good idea, though.
As for A032R's, I might ask what the car is going to be used for. As a street tire, they are arguably the best thing money can buy but they don't last very long. As an autox/opentrack tire, they are at the bottom of the list in terms of absolute grip. (FWIW in that scenario, 205/60-13 Kumho V700 Victoracers are stickier and cheaper.)
IMHO you will have a hard time finding any 13" tire worth having... with a sidewall shorter than a 60-profile. As far as sticky street tires go, probably your best all-around bet is the 205/60-13 Yokohama AVS Intermediate, in-stock for $59ea at http://www.tirerack.com
Hope that helps,
Jon
Old Jan 16, 2002 | 03:25 AM
jsi's Avatar
jsi
For a compeition tire that can also be used on the street, i'd highly recommend the Toyo RA1. I know several people that use them on the street and get 8-10K miles out of a set. They are available in 205-60-13 size too, which will fit fine on a 5.5" rim although that rim size is at the minimum recommended width. Should still work fine...
Old Jan 16, 2002 | 04:46 AM
CivicSiRacer's Avatar
I didn't like the A032Rs they took too long to heat up for autocross. I'm pretty sure they make great track tires.
SIR EF9
Mar 24, 2009 06:58 AM
TurboEM1
Aug 13, 2008 01:45 PM
BB1LOViN
Dec 20, 2007 04:46 PM
FerioVtec94
Feb 20, 2004 10:35 AM
00ek9
Jul 22, 2002 02:43 PM
