Does this look like a bad oil pump?
Old Feb 6, 2005 | 10:29 AM
Ecugrad's Avatar
Default Does this look like a bad oil pump?
Yeah, thats leaking oil. That much oil came out BEFORE the car even heated up!
The only think I can think of it being is the oil pump. That ebay kit was the bigest waste of $. I just hope like hell the pistons hold together cause that and the HG are the only two things left out of it! Needless to say that a new GENUINE HONDA oil pump will be on its way to me ASAP unless someone on here can tell me its something else.
Old Feb 6, 2005 | 10:48 AM
fourthgenhatchB17's Avatar
Default Re: Does this look like a bad oil pump? (Ecugrad)
What ebay kit? Maybe its the front main seal? Oh, and replace the timing belt now, it looks like its contaminated with oil.
Old Feb 6, 2005 | 10:52 AM
ThefirstPACT's Avatar
Default Re: Does this look like a bad oil pump? (fourthgenhatchB17)
There is a crank seal there to! Replace that first, no need to spend 100+ dollars on a oil pump when it just may need a crank seal. Like ^ said replace the t-belt.
Old Feb 6, 2005 | 10:54 AM
Default Re: Does this look like a bad oil pump? (ThefirstPACT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThefirstPACT &raquo;</TD></TR><TR><TD CLASS="quote">There is a crank seal there to! </TD></TR></TABLE>
Thats the front main right?
Old Feb 6, 2005 | 11:07 AM
Ecugrad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">What ebay kit? Maybe its the front main seal? Oh, and replace the timing belt now, it looks like its contaminated with oil.</TD></TR></TABLE>
This is a newly rebuilt motor. I purchased a rebuild kit from ebay and this oil pump came with it.
I am assuming you are talking about #22 on this page:
Old Feb 6, 2005 | 11:23 AM
Yes 22 is it. If its newly rebuilt, why does the oil look soo black? Oh and i see ur problem, ur using Megan products, lol, just playin. Change 22 first and see what happens.
Old Feb 6, 2005 | 11:29 AM
Ecugrad's Avatar
Thats the first oil put in it, I need to change it. This motor has ran only about 30 mins or so.
It just worries me that a new pump seal bit the dust sooo quick.
Dont hate on Megan. Its ok stuff.
Old Feb 6, 2005 | 06:25 PM
Maybe the seal was a cheapy one? Go with OEM. i have been to Megans showroom/warehouse/main office building...and some of their stuff is actually OK. Stay away from their headers, what pieces of junk they are.
Old Feb 6, 2005 | 06:37 PM
untitled's Avatar
Its the main seal, replace it. Process of eliminations own you.
Old Feb 7, 2005 | 01:58 AM
Ecugrad's Avatar
Default Re: Does this look like a bad oil pump? (untitled)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untitled &raquo;</TD></TR><TR><TD CLASS="quote">Its the main seal, replace it. Process of eliminations own you.</TD></TR></TABLE>
Thanks, thats what I will try.
Old Feb 8, 2005 | 06:46 AM
Thats the crank seal! Yes number 22. The REAR main is on the fly wheel side of the motor!
Old Feb 8, 2005 | 09:25 AM
Ecugrad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThefirstPACT &raquo;</TD></TR><TR><TD CLASS="quote">Thats the crank seal! Yes number 22. The REAR main is on the fly wheel side of the motor! </TD></TR></TABLE>
Yeah, thats the only thing it could be. I know what happened, I left the little "washer" out that goes behind the timing belt pulley. The timing belt walked over too far and took out the seal. I almost ruined my fresh rebuild on something real stoopid
Old Feb 8, 2005 | 10:48 AM
Glad your got it!
GIT
R
DONE
Old Feb 8, 2005 | 10:51 AM
untitled's Avatar
Git R Done, dets RITE!
Old Feb 8, 2005 | 11:38 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ecugrad &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, thats the only thing it could be. I know what happened, I left the little "washer" out that goes behind the timing belt pulley. The timing belt walked over too far and took out the seal. I almost ruined my fresh rebuild on something real stoopid </TD></TR></TABLE>
Make sure u install those "washers" facing in the right direction.
Old Feb 8, 2005 | 11:44 AM
ssl2k's Avatar
On a side note you should have an external oil pressure gauge hooked up especially since it is a new motor...even if it is just temporary just to make sure during the break in everything is runnin a-OK
somick
Aug 15, 2017 08:14 AM
chadwick16
May 21, 2005 10:40 AM
snatch
12
Mar 15, 2005 10:12 AM
BlendedEJ8
May 31, 2003 11:22 AM
Boostless97Lude
Jan 8, 2003 09:53 AM
