d15b question
Old Feb 6, 2005 | 09:51 AM
bbrian's Avatar
Default d15b question
i was wondering if i swap a d15b vtec in my 91 hatch with a si tranny and a few bolt ons would i make it into the 14's
Old Feb 6, 2005 | 10:00 AM
crexer's Avatar
Default Re: d15b question (bbrian)
um...sure
Old Feb 6, 2005 | 11:32 AM
CRseXxy's Avatar
no. ur best bet would be to turbo an HF due to the low compression. with the HF's strong tranny u'll be running 13's
Old Feb 6, 2005 | 11:40 AM
bbrian's Avatar
whats so good about the hf tranny are the gears alote shorter than the si or something
Old Feb 6, 2005 | 11:45 AM
iamjdm's Avatar
Honestly if you are goin to dump all this money into a motor that hasnt that much potential, why dont you just invest into some make more sense power and go B or K series, with the same amount of money you could obtain the same power that you would with spending 1,000 dollars on the D series. Just kick back and think about it.
Old Feb 6, 2005 | 11:49 AM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRseXxy &raquo;</TD></TR><TR><TD CLASS="quote">no. ur best bet would be to turbo an HF due to the low compression. with the HF's strong tranny u'll be running 13's</TD></TR></TABLE>
That's just wrong, have some mercy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbrian &raquo;</TD></TR><TR><TD CLASS="quote">whats so good about the hf tranny are the gears alote shorter than the si or something</TD></TR></TABLE>
And I'll let you slide because you just don't know better. Anyhew, it takes more then just an engine to run a 14 second quarter, you have to account for drivetrain, traction, chassis configuration, and driver skill. To put this into perspective, a newb in the Forced Induction forum was complaining last week about only doing a 15.42 with a boosted B18C5. If you suck as a driver or if a setup is done wrong you wont go fast, simple as that. Also, asking how fast you would go in the quarter in this forum and most others in the Honda-Tech community is a big no-no, a sin called E-RACING.
On the matter of the HF transmission it is good for Fuel economy and that is it, end of story.
Old Feb 6, 2005 | 12:00 PM
Default Re: d15b question (iamjdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iamjdm &raquo;</TD></TR><TR><TD CLASS="quote">Honestly if you are goin to dump all this money into a motor that hasnt that much potential, why dont you just invest into some make more sense power and go B or K series, with the same amount of money you could obtain the same power that you would with spending 1,000 dollars on the D series. Just kick back and think about it.</TD></TR></TABLE>
And you are also a fool. $1,000 on a D-Series gets you a nice homemade turbo seup and off you go in the general area of 140-180whp and 140-170 ft-lbs. ~Disclaimer~ This is just general from what I have gathered from not only this sites Forced Induction Forum, but also from other forums not limited to but including Turbo D16. A B-Series Swap at going rates, not "I got a deal from my brother's friend's cousin's mother's third boyfriend", is going to go well over $1,000. And a K-Series swap in our chassis is going to be pushing nearly $8,000 when all is said and done, and that is rough number not including the hood you will need to make it fit.
Old Feb 6, 2005 | 12:32 PM
Reason's Avatar
Default Re: d15b question (CRseXxy)
Please tell me you are joking.
Old Feb 6, 2005 | 12:38 PM
Reason's Avatar
You must not know ****. The only way you are going to get a b-series swap for $1000 is if you buy a car that was wrecked(90-93 integra), and even then you wont have as much power as turbo zc or even most 1.5 engines, excluding the hf and cx engine. D-series have lots of potential, not as much as a b-series engine but they have enough. Just look on d-series.org, or turbod16.com.
Old Feb 6, 2005 | 12:40 PM
Reason's Avatar
Default Re: d15b question (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">
And you are also a fool. $1,000 on a D-Series gets you a nice homemade turbo seup and off you go in the general area of 140-180whp and 140-170 ft-lbs. ~Disclaimer~ This is just general from what I have gathered from not only this sites Forced Induction Forum, but also from other forums not limited to but including Turbo D16. A B-Series Swap at going rates, not "I got a deal from my brother's friend's cousin's mother's third boyfriend", is going to go well over $1,000. And a K-Series swap in our chassis is going to be pushing nearly $8,000 when all is said and done, and that is rough number not including the hood you will need to make it fit.</TD></TR></TABLE>
Old Feb 6, 2005 | 01:40 PM
eumoria's Avatar
the HF tranny is the absolute worst tranny for acceleration. You're better off with ANYTHING other than the HF tranny. DX is a grand step up from the HF. Si being the best (ZC is basically an Si tranny with a DX final drive, also very good)
Also, the HF engine is an 8 valve, making it terrible for any type of boosting... along with everything about that engine incld. the cams and the intake mani make it horrid for any modification. You, my friend, need to read up on these cars before you shoot your mouth off.
Old Feb 6, 2005 | 01:56 PM
CRseXxy's Avatar
Default Re: d15b question (eumoria)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eumoria &raquo;</TD></TR><TR><TD CLASS="quote">
Also, the HF engine is an 8 valve, making it terrible for any type of boosting... along with everything about that engine incld. the cams and the intake mani make it horrid for any modification. You, my friend, need to read up on these cars before you shoot your mouth off.</TD></TR></TABLE>
im not retarded, i was being sarcastic. But ill stop being a *****. Ive heard of low 15's on a mini me swap with ur basic driver and simple bolt-ons. I personally own a b16 but i think a sohc vtec is def a good choice. 500 dollars and a few hours and u got v-tec, add a junkyard turbo for cheap and ur set, where the hell could u go wrong?
Old Feb 8, 2005 | 03:41 PM
spoonef's Avatar
375 buddy not 1000
Old Feb 8, 2005 | 07:50 PM
CRseXxy's Avatar
Default Re: d15b question (spoonef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonef &raquo;</TD></TR><TR><TD CLASS="quote">375 buddy not 1000 </TD></TR></TABLE>
375 on engine and turbo??? if thats the case send me to whoever sold u ur setup
Old Feb 8, 2005 | 11:16 PM
Reason's Avatar
is that ofr the turbo by itself.
Old Feb 10, 2005 | 01:55 PM
ShitBoxCrx's Avatar
the DX tranny is SI gearing with a DX final drive buddy...
Old Feb 10, 2005 | 02:01 PM
CRX_Control's Avatar
Default Re: d15b question (ShitBoxCrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShitBoxCrx &raquo;</TD></TR><TR><TD CLASS="quote">the DX tranny is SI gearing with a DX final drive buddy...</TD></TR></TABLE> who are you talkin to? no one needed to know that..
Old Feb 10, 2005 | 02:26 PM
On the off topic, wouldn't it be easier to say the only difference is the final drive? Ok, Back to the topic at hand.
Old Feb 12, 2005 | 03:14 PM
EfhATcHy's Avatar
hell yea u should !! if u knoe how to drive also that would help alot!!!
Old Feb 12, 2005 | 03:47 PM
ShitBoxCrx's Avatar
i was responding to **** post guys. "(ZC is basically an Si tranny with a DX final drive, also very good)" should have jumped on that not on me. Why dont you just say its a DX tranny?. And its wrong.
Old Feb 12, 2005 | 04:33 PM
DocTaDrift's Avatar
dood just slap a ton of stickers and stuff on your car and youll make 100 hp easy
bLuBoOrEx89_RAZORS_
28
Nov 27, 2007 03:22 PM
nihad
14
Jan 18, 2007 03:24 PM
boostedSI90hatch
Dec 6, 2006 05:21 AM
nissaninahondaworld
Dec 8, 2005 08:20 PM
subgeniusdude
23
Jan 7, 2004 12:43 PM
