What ECU is in my car?
I have a 1988 DX with a 2nd Gen. B16a in it. I am sure my ECU is fried because when I turn the ignition to the ON position the LED stays on which I figured means code (bad ECU). What ECU does this car HAve? If I remove it, can I decode it from the numbers that are written on it? What's the best place to get one?
was your ecu chipped? might be bad soldering in that case you can just cut the jumper and the ecu will go back to stock... i am in st. catharines and if you send me your ecu i would be happy to look it over for you... crxboy69@hotmail.com you can add me to msn
