help car will not start????spark but no signal to injectors
Old Feb 6, 2005 | 07:13 AM
civtegra_hybrid's Avatar
Default help car will not start????spark but no signal to injectors
the car just died on me . I checked my spark and that **** is strong, but when I took off the plugs for the injectors and hooked a light up to it, it didn't light up when we were cracking it, I thought it was the eng harness shorting out, so we replaced that ****, and the same thing, we replaced the main fuel pump relay, and still the same ****. we tryed a diff. ecu. and nothing, we checked the all the grounds. even to the injectors. pls. help were lost. the next thing Im about to do is check the fireing front the ecu to the injectors to see if it's even sending power front the ecu to the injectors when cracking. does anyone have any other Idea's??? pls help
Old Feb 6, 2005 | 03:13 PM
Default Re: help car will not start????spark but no signal to injectors (civtegra_hybrid)
any one?????
Old Feb 6, 2005 | 04:33 PM
93civiceg6's Avatar
check the ecu fuse under the hood
Matthewhughes
29
Aug 5, 2014 03:18 PM
B16Civic93
Jan 20, 2014 04:30 PM
N'viouzEF9
Mar 4, 2011 09:16 AM
jansenrw
Nov 21, 2005 06:16 PM
jansenrw
Nov 19, 2005 08:44 PM
