88-91 CRX Suspension fit onto 92-95 Hatch w/ ITR LCA's?
As the title says can a crx suspension fit onto a 92-95 civic hatch with itr rear lower control arms? Can't seem to find anything besides that right now as far as shocks and coilovers.
Thanks
Thanks
yeah it would fit but u would need or have alignment off by 1/16" or something like that
as this is the scenerio for the EF chasis when installing EG suspension
so it would be the same I assume right
I think you will also need to swap front drop forks with an EF or DA - the shocks in the EG/DC have a larger diameter than EF/DA shocks.
Can anyone please confirm what exospeed said? Or if there is a way to fabricate them safely onto my civic.
http://www.g2ic.com/forums/showthread.php?t=30796
There's confirmation, it's a well known fact around the DA/EF world that you can use EG/DC shocks if you swap front drop forks - so the exact opposite is true in your case.
hmtcrxsir
Mar 19, 2006 07:46 PM
