WANTED....91-95 NSX front Calipers
Munkyw3rkz.webs.com
wanted 91-95 NSX front calipers
please do not PM me, i dont have access to the net
email me please...thanx
when viewed please bump
if you are using the gsr spindles....you can use the 90-91 acura legend,those are just as big if not bigger,plus you will get out a little cheaper also.
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1700anddroping »</TD></TR><TR><TD CLASS="quote">if you are using the gsr spindles....you can use the 90-91 acura legend,those are just as big if not bigger,plus you will get out a little cheaper also.
thanx bro, but i believe its the 94-95 Legend that is the same as the NSX, but they dont have NSX onit...thats Y..if not then ill will just get the legends! worst come to worst ill just get spoons!!!
</TD></TR></TABLE>thanx bro, but i believe its the 94-95 Legend that is the same as the NSX, but they dont have NSX onit...thats Y..if not then ill will just get the legends! worst come to worst ill just get spoons!!!
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1700anddroping »</TD></TR><TR><TD CLASS="quote">why pay all that money for spoons,it's just the name.no it is indeed the 90-91 lengend.i have done this and they are huge.....
the weight saved on the spoon make a huge difference in steering and handling because of the lost weight, if i remember correctly its 10-12 lbs less on each caliper
</TD></TR></TABLE>the weight saved on the spoon make a huge difference in steering and handling because of the lost weight, if i remember correctly its 10-12 lbs less on each caliper
sorry but i don't think those calipers weigh that much or no where near it.i am in the process of making a set of axles and hubs for my h22 ek hatch...if i ever get time to work on it.all in all when said and done.....axles that w/stand over 500 for lets just say acouple of hundred bucks....will post pics when i get ready to put everything together.
Munkyw3rkz.webs.com
http://www.j-w-racing.co.uk/ac....html
stock ITR unit is 10.3 pounds and the spoon caliper is 5.7lbs....this is the info i have gathered!
my figure of 10-12lbs was high but 5lbs unstrung weight is a good improvment!
your not gonna be able to tell a difference.i think it is.for every 100 lbs,you gain a tenth.....so taking off 10 lbs dead weight ain't gonna help much,now if you took that off rotational mas....that is a whole nother ball game....now i will believe 5lbs per,but not 10.and that is why they are so dam high....they are made out of aluminum and 2-4-6 piston caliper.but for the money i still say go with 90-91 legend....those other yrs may work...but i know for a fact the 90-91 legends do.
Munkyw3rkz.webs.com
yes for every 100lbs is roughly a tenth in hte 1/4.....but i am no getting these to save weight at the drag strip...if so i wouldnt have dropped my 5 lug set up which is 43lbs heavier then my 4x114 set up (weight is without wheels)yes i see your point in the $
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ModernChemistry »</TD></TR><TR><TD CLASS="quote">WTF ARE YOU BACK OR WHAT?????????
its Max
no fawker!!! you get my email?????
its Max
</TD></TR></TABLE>no fawker!!! you get my email?????
i was in autozone looking up the same thing. they list having the nsx calipers, like 51.99 each side + 75 core. when i tried to order they were outta stock. i dont know if they were oem's, but its worth checking out. i know you wont find any on here that cheap.
Munkyw3rkz.webs.com
yea i looked into that myself....they had two different brands...but they aint OEMs they are replacements...thing is if they notice the caliper you bring in is different from that one since 1 piston 2 piston you know!
I've already asked autozone about trading in another caliper.... they will not give you credit unless you bring in a matching caliper. (so if you buy an NSX caliper, to get the credit you need to give them an NSX caliper)
But yea, they're always out of stock. I guess NSX owners never get their brakes fixed at Autozone
i turned in my old rear dc4 calipers as the core on my itr front calipers.
gotta just find the right guy to bring the calipers to i guess, or girl for that matter.
Scotty Dosent Know
Suspension & Brakes
Jun 28, 2008 09:13 PM
