Wiring Vtec on ECU??????
A8 VTEC solenoid
B5 VTEC oil pressure switch
B19 Knocksensor
C8 Second oxygen sensor
Do i cut the Existing wires and connect all the wires to those pins?
ECU=Plug== =============Harness.
Cut Here ^=====VTEC Then Run the wires to the Sol, switch and sensrs
Is this how im suposed to do it. its going to be on a 90 DX
B19 Knocksensor
From: I told you to wait in the truck in Texas, United States
CHECK the FAQ section..
for how to wire your O2 sensors..
[if you want it to run right that is...]
Here are some good B-16 links:
http://www.geocities.com/dropp...p.htm
http://www.phatwhippincrx.20m.com/custom.html
http://tjshondas.20m.com/b16ainstall.html
http://crxpage.com/
http://www32.brinkster.com/tjshondas/default.htm
http://b16a.honda-perf.org/theswap.html
http://crxpage.com/
