Install new cam gears.....have a question though....
Old Feb 5, 2005 | 09:48 PM
ExVtec's Avatar
Default Install new cam gears.....have a question though....
I got a set of Gsr cams for my boosted B16a2.
I swapped the gears and added adjustable cam gears.
Everything went smooth, followed the tightening sequence and torque specs. I was adjusting the cam gears to 0 degrees and I turned the exhuast cam over easy enough, but when I went to move the intake cam, it would only move if I applied alot of force.
I am not sure if the exhuast cam is to loose or the intake cam is to tight...
Is this normal, or do I need to pull it apart and double check everything...I placed assembly lube on the cam bearings and what not...
Any help would be greatly appreciated.
Thanks all.....
Old Feb 5, 2005 | 11:04 PM
ExVtec's Avatar
Default Re: Install new cam gears.....have a question though.... (ExVtec) - fixed...
I took it apart and realized I didn't have the dizzy slot completly in the intake cam key slot...
All is well...
titosek4
Aug 11, 2009 06:04 PM
EGunit
Aug 5, 2007 11:23 PM
Reis
Jul 20, 2005 02:44 PM
rough_draft
Mar 26, 2005 05:32 PM
