Car wont go into any gear with the motor running, cant start car while in a gear, help
I was driving home and I felt something really odd when I put the car into fourth gear. I then realized after trying to downshift comming into a stop light I could not put the car into any gear. On the drive to work I had noticed a very slight pop when I slowly accelerated from a stop. I am fairly confused as to what to do since I did not hear/feel any symtoms from a bad throw out bearing, and I don't grind gears or try to race my car all over town. I can also easily shift all the gears in my transmission when the car is off. If i try to start the car in gear the cars tries to lurch foward. After searching I read that the springs in the clutch could of broken, or my pilot bearing may have broken. Some other things to know, I had firm petel feel, plenty of fluid, and the clutch would engage smoothly up until tonight. I have recently replaced the clutch and throwout bearing(10k miles). Any input on this would be appreciated.
your clutch went out. this happened to me about a month ago. probably the spring in your clutch disc broke
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">3rd-gen integra? The fork should move about 12mm back & forth. IF that's ok, then pull the tranny & look for something broke inside the bellhousing.
Pull the tranny is right. Thats a clutch problem, disc most probably.
Its something inside the housing, I am thinking it is not the actual clutch tho. I removed the starter motor, and when i press the clutch in the pressure plate only moves about 1mm at the most, not enough to free the clutch from the fly wheel. The fork however moves about 12mm. I am for now going to assume its the throwout bearing, or somehow the fork got bent. I will remove the tranny on monday and get a better idea. I'll probably do a write up for a fast clutch install since I know the one in those haynes manuals are shitty as all hell.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Geno »</TD></TR><TR><TD CLASS="quote">Its something inside the housing, I am thinking it is not the actual clutch tho. I removed the starter motor, and when i press the clutch in the pressure plate only moves about 1mm at the most, not enough to free the clutch from the fly wheel. The fork however moves about 12mm. I am for now going to assume its the throwout bearing, or somehow the fork got bent. I will remove the tranny on monday and get a better idea. I'll probably do a write up for a fast clutch install since I know the one in those haynes manuals are shitty as all hell.</TD></TR></TABLE>
quickly take the hydraulic lever out and take a peek inside the case, you can prolly see if anything is busted
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Code Blue »</TD></TR><TR><TD CLASS="quote">
quickly take the hydraulic lever out and take a peek inside the case, you can prolly see if anything is busted</TD></TR></TABLE>
I was thinking about doin that, gunna have to grab a mirror and a good flashlight cus my head is too big to fit between the radiator and the tranny
HopefulVtec
Jul 16, 2015 07:15 PM
tallguy21
17
Feb 27, 2011 05:49 PM
mnskateboarder
Transmission & Drivetrain
11
Oct 25, 2009 08:01 PM
BlackOutIntegra
May 6, 2004 10:47 AM
