Pic's of the new Track Car. (600hp)
Finnaly got the cobra tuned the way that I want. Able to push all the way up to 11lbs on the motor but have backed it off to 9lb's. on full boost. With the boost numbers as they are and the jetting and other special bits I am looking at ~600hp at the crank wrapped in a 2200lb frame. Just got to get something bigger then a 345 on the rear and off to the track we go and see what she will put down.
Its a domestic I know but heck its a lot of fun to drive, if racelegal ever opens up again i will take it down but I have a feeling I am going to get kicked for safety on the first run so it better be a good one. Its setup for open track right now but it's street legal so I am going to have some fun for a little while before it goes back into the garage for some more suspension work.
Specs are as follows.
350 (Racing Head Service) SBC with forged crank, 4-bolt block,
roller tip rockers,
turbo TRW pistons
hydraulic cam
Mallory comp 9000 dist
HD oil pump
Hooker headers
oil cooler
flowmasters
Jacobs ignition box
B&M low profile blower with complete set of different size pulleys
Holley 800CFM double pumper.
Wideband 02 setup, in dash gauge
New Richmond Gear super T-10 four speed
Dual face Centerforce clutch,
steel shatter-proof bellhousing.
Franklin Grand National quickchange rear-end
Wilwood discs and calipers
gun drilled full floating axles,
Torsion gear type posi [extra QC gears and Detroit Locker].
4 link rear end with full adjustability.
Other unique features:
3 quart Accusump in trunk, (Manual switch integrated into cabin.)
Gel battery with cut-off switch, (extra hidden cutoffs in the cabin
Engine start button.
Moroso extra capacity oil pan (Accusump + Moroso + 350 = a lot of oil)
4-Row radiator
Auxiliary elect fans
5-point harness,
Centerline Convos for street,
Recently received its third black paint job
Foam Filled fuel cell.
Custom Shroud
Undercar skid plates for frame/motor/glass protection
Multi-position temperature sensors
Quick release bumper’s/seats for easy removal at track
Trunk mounted battery.
Emergency brake mounted on driveshaft.
Driveshaft hoops.
Shifter with reverse lockout
Master cylinders frame mounted so you can lift off body without removing or draining brake lines.
Bolt-in supplemental roll-bar hoop that ties into the existing Shelby type hoop behind the driver, has NASCAR bar and is tied into the frame at all points, rear bar is tied into frame as gusseted as well.
Custom tow bar
Front brakes are Corvette rotors and calipers with billet aluminum hubs (upgraded C4 setup)
Larger GM race bearings
Dual master cylinders with balance bar. (Adjustable brake bias)
Alden coilovers, (two way adjustable (two extra for spares).
Mounted Wilwoods are the upgraded C4 setup
Power Steering Setup
roller tip rockers,
turbo TRW pistons
hydraulic cam
HD oil pump
Hooker headers
oil cooler
flowmasters
Jacobs ignition box
4-Row radiator
5-point harness,
Custom Shroud
Driveshaft hoops.
Custom tow bar
Shoot'n for 10's on street tires and without the juice. The motor can take ~150hp of nitro on top of the full boost so maybe just maybe low 10's with that installed. Biggest problem is getting it to go in a straight line. 90 inch wheelbase realy sucks.
The drivetrain had a blown/nos 454 in it before so it is real stout but it was a heavy monster back then from what I have heard. Also I have been playing with the gear ratios with the quickchange and might just set it up so you never get out of 3rd in the quarter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [D6 »</TD></TR><TR><TD CLASS="quote">]
thats a monster</TD></TR></TABLE>
AzG35
Dec 11, 2004 04:21 PM
