Neuspeed Strut Bars
Old Feb 5, 2005 | 06:12 PM
Leets's Avatar
Default Neuspeed Strut Bars--SOLD
I've got a Used Neuspeed front upper strut bar for an 88-91 Civic/CRX (also fits 90-93 Integras w/o ABS). It's black and is in good condition. I'm asking $60 obo for this bar. SOLD
I've also got the same bar but brand new, unopened still in the box. The bar retails for about $120, but I'm asking $80 for it. SOLD
Both items are local pick-up in Southern Cali, OC/LA area only please. I currently have an 04 civic (damn the suspension design change) and am always looking for parts so I'd be interested in any similar value trades that anyone might have. Thanks for looking.
Modified by Leets at 3:50 AM 2/6/2005
Modified by Leets at 3:52 AM 2/6/2005
Modified by Leets at 12:25 AM 2/8/2005
Modified by Leets at 5:45 AM 2/8/2005
Modified by Leets at 6:57 AM 2/14/2005
Old Feb 5, 2005 | 06:25 PM
hatchinprogress's Avatar
Default Re: Neuspeed Strut Bars (Leets)
pm sent
Old Feb 6, 2005 | 08:03 PM
Leets's Avatar
Default Re: Neuspeed Strut Bars (hatchinprogress)
1 still available
Old Feb 7, 2005 | 09:26 AM
Leets's Avatar
back to page 1
Old Feb 7, 2005 | 09:28 AM
krack's Avatar
check pm or email me when i can come get
Old Feb 7, 2005 | 10:09 AM
Leets's Avatar
Default Re: (krack)
pm sent
Old Feb 11, 2005 | 07:29 AM
krack's Avatar
hey man got a question for you, are not these nuespeed bars suppost to be a solid piece of bar and not hollow.. see nuespeed told me that all their bars are solid and never hollow yet the one i got is hollow so please expain to me..thank you
Old Feb 12, 2005 | 01:31 PM
Leets's Avatar
Default Re: (krack)
The Neuspeed bar is a "Twin tube, solid mount design." This means that bar is one solid piece, but since they use steel tubing, it's hollow. Having the bar hollow makes the bar significantly lighter. The reason it's referred to as a solid bar is because it is all one piece. Most other manufacturers' bars consist of two brackets which the bar is then mounted on to. The two bracket design isn't as effective because the bar still allows flexing where it bolts to the brackets. That is the reason most cars that come stock with a strut bar use a one-piece design. The one-piece Neuspeed design doesn't allow any flexing because it is one solid bar, not using any brackets. Hope that helps explain it.
Old Feb 12, 2005 | 08:54 PM
krack's Avatar
ya that did. thanks so the nuespeed bar that is made for the rear, is not as good cause its made in 3 pcs.
Old Feb 13, 2005 | 10:46 AM
Leets's Avatar
Default Re: (krack)
I had that bar in my 91 si, and it was really good. You're right, it isn't as strong as one solid piece, but it is stronger than most. The reason it's still stronger than the bars that have the single bolt mount on each end is because Neuspeed uses two bolt at each end. This reduces flexing because even if one mounting point begins to flex it will still be held at the other. At first I expected some flexing when I put it in my car, but it stiffened up the rear a lot. Overall, it's a great piece.
Old Feb 13, 2005 | 05:20 PM
Default Re: (Leets)
thanks leets
Old Feb 25, 2005 | 08:25 PM
krack's Avatar
Default Re: Neuspeed Strut Bars--SOLD (Leets)
mr leets im bumping this up because i would love to know why the bar you sold me doesnt even come close to fitting on my ride you said this was the one for the da and its way to bib wana help me understand??
dc2go
Sep 28, 2007 02:17 PM
98Psi ITR
Dec 22, 2005 08:25 PM
tyflip2
Jun 8, 2005 06:41 PM
integsr99
Mar 28, 2004 05:58 PM
ChadTeg
Dec 9, 2003 09:19 AM
