What ECU will be better on a Zc?
Old Feb 5, 2005 | 05:30 PM
ivanson's Avatar
Default What ECU will be better on a Zc?
Im planning to get a Zc swap on my 88 crx
and im not sure which ecu will put better
performance on the Zc. I was planning to buy a
pm6 si and chip it. Any suggestions
Thanks
Old Feb 5, 2005 | 05:52 PM
Creepshow S60's Avatar
Default Re: What ECU will be better on a Zc? (ivanson)
A lot of people use the PG7. Some notice a difference and others don't. I'd PM some members and ask around. You can always try the zc resource online as well. PG7 and PM6 are the most commonly used.
Old Feb 5, 2005 | 06:04 PM
ivanson's Avatar
What about the tranny? Can I use an
LS tranny for the Zc.
Old Feb 5, 2005 | 06:21 PM
EP3_05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivanson &raquo;</TD></TR><TR><TD CLASS="quote">What about the tranny? Can I use an
LS tranny for the Zc.</TD></TR></TABLE>
No a bseries LS trans will not bolt to the d series(zc) block. You need to use a cable d series trans
Old Feb 5, 2005 | 06:39 PM
91bluehatch's Avatar
im using a 88 si ecu and it sux, its alot better than the heartbreaking hf ecu i had. The ecu only allows me to goto 6500rpm's. Im gonna order a zc ecu asap when i can get some cash. The tranny i would go si from a 88-91 civic/crx si
Old Feb 5, 2005 | 06:45 PM
ivanson's Avatar
Default Re: What ECU will be better on a Zc? (91bluehatch)
91bluehatch
Does that si ecu only let u redline to 6500?
or the HF one...Cause mine is at 5500 and was
planning to get a pm6 to redline higher
Old Feb 5, 2005 | 06:51 PM
ivanson's Avatar
hey would a pm7 zc ecu run on my stock crx for now?
Without breaking or messing up my engine?
Reply back thanks
Old Feb 5, 2005 | 07:06 PM
the hf ecu would only let me hit 5000 and the si 6500. I think u could go ahead and run the pg7 no probs.
Old Feb 5, 2005 | 07:26 PM
AnarkyPhreek's Avatar
ur right, my ecu is from a hf and i had it sent to california to be tuned to si- its now at 6500- but i suggest getting an ignition system so u can kick in vtec at a lower rpm.. i have a msd with a 4400 pill and u would be surprised at the difference it makes to run vtec for over 2000 rpm
Old Feb 5, 2005 | 07:27 PM
Default Re: (AnarkyPhreek)
Vtec the ZC has no vtec
Old Feb 5, 2005 | 08:09 PM
PHOBIA's Avatar
yes it does, the sohc vtec zc pictured here. http://www.ardperformance.com/...index
ZC 1.6 SOHC VTEC
1.6 SOHC VTEC Honda Motor. Direct from Japan. Includes engine and ECU (For 92-95 Civic/Del Sol. Direct bolt in, no motor mounts required. Also fits 96+ Civic with OBDII Adapter.
Engine Only for $895.95
Engine Code ZC If you are ready to buy a motor and want the freight charges click here
Displacement/Valve Layout 1.6 Liter SOHC VTEC (Variable Valve Timing)
Compression Ratio .
Horsepower 130 HP
Torque .
Old Feb 5, 2005 | 08:14 PM
crxnj's Avatar
Default Re: What ECU will be better on a Zc? (91civic)
Theres a shitload of zc motors..This guy should have said which one he wants to swap in..
Run ecu thats meant for the motor..
Old Feb 5, 2005 | 08:54 PM
pyro_freak8's Avatar
i'm running a PR4-A52 ecu out of a '90 integra that i chipped myself and i am running PM7 maps with dataloggin enabled right now on my DOHC ZC in my '91 CRX
Old Feb 5, 2005 | 09:27 PM
hahagasdcrx's Avatar
Default Re: (pyro_freak8)
the pg7( 88-89 integra ecu) has a different fuel map than the pm6. You will end up running a little rich with the pg7, but your redline would be @ 7200rpm. The extra 600 rpm def. makes a difference. The pm7 is the perfect ECU for the dohc ZC but has a speed governor of @112mph( like anyone here drives that fast).
Old Feb 5, 2005 | 09:35 PM
ivanson's Avatar
Default Re: (hahagasdcrx)
so can i go ahead and run a pm7 ZC
on my stock for now untill i get my swap?
Old Feb 6, 2005 | 07:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hahagasdcrx &raquo;</TD></TR><TR><TD CLASS="quote">the pg7( 88-89 integra ecu) has a different fuel map than the pm6. You will end up running a little rich with the pg7, but your redline would be @ 7200rpm. The extra 600 rpm def. makes a difference. The pm7 is the perfect ECU for the dohc ZC but has a speed governor of @112mph( like anyone here drives that fast). </TD></TR></TABLE>
True.
Some people bitch about a speed governor of 112mph...but honestly, we drive honda civics...who cares? let the supra guys worry about speed governors...that's what i say.
Old Feb 6, 2005 | 08:00 PM
kulangot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91bluehatch &raquo;</TD></TR><TR><TD CLASS="quote">im using a 88 si ecu and it sux, its alot better than the heartbreaking hf ecu i had. The ecu only allows me to goto 6500rpm's. Im gonna order a zc ecu asap when i can get some cash. The tranny i would go si from a 88-91 civic/crx si
the hf ecu was free...
flyjum
Jul 4, 2006 09:14 AM
90ED9
Jul 26, 2004 12:28 PM
Toptul_Honda
36
Dec 26, 2003 08:38 AM
muskrat
Oct 10, 2002 07:09 PM
honduh-guy
Feb 26, 2002 09:19 AM
