tube/pipe bender
Old Feb 5, 2005 | 03:42 PM
number7s's Avatar
Default tube/pipe bender
i was wondering if it is possible to make a bender from scatch with like hydralic pumps or something, or does any know any good places, i need to bend like 3in diameter steal pipes
Old Feb 5, 2005 | 03:59 PM
Engloid's Avatar
OG Fabricator
Default Re: tube/pipe bender (number7s)
If you spend hours investigating the types of benders, you will end up at a dead end...
In order to bend what you want, you would have to pay about $70k for a mandrel bender. To reproduce it....well, if you're asking, you can't do it. No offense...just that if you were an industrial or mechanical engineeer with ability to design and produce such a complex machine, you'd already have this knowledge.
I was wanting a bender, and discovered that even a $6k rotary draw bender will change the diameter of the tube when bending. It's good for roll cages, but nothing like intake or exhaust piping. Definitely not good for headers.
The best option is to buy the bends. That's why there's so many people buying bends.
Old Feb 5, 2005 | 04:15 PM
number7s's Avatar
well im building a bike and could i like cut where the bend would be and then weld it at an angle?
Old Feb 5, 2005 | 06:09 PM
Engloid's Avatar
OG Fabricator
Ok. For building a bike frame, you will likely be using PIPE, which you can probably bend with a pretty cheap bender from Harbor Freight. Or if you want something a bit nicer, look into the JD2 benders. There's other brands that are a bit cheaper, but the same design.
Forget most of what I said in my first post about mandrel stuff...as you don't need that for a bike frame.
Old Feb 5, 2005 | 07:20 PM
tony1's Avatar
Default Re: tube/pipe bender (Engloid)
We use the JD2 Model 3 and the shop and it works great.
Old Feb 5, 2005 | 09:39 PM
HotRodTeg's Avatar
Default Re: tube/pipe bender (tony1)
Tony do you guys use the Hydraulic with it? of is it manual. Im gonna be ordering mine on monday so I was wondering if the hydraulic conversion is worth the money.
Old Feb 6, 2005 | 05:43 AM
tony1's Avatar
Default Re: tube/pipe bender (CrazyCompression)
We don't have the hydraulic option, we're cheap. lol I think it would be great to have, but the manual does the job fine. Make sure you get the "anti springback bar". It's hard to explain how it works, but you'll need it, it'll save alot of time with chromoly.
Old Feb 6, 2005 | 10:10 AM
HotRodTeg's Avatar
Sounds good thanks for the advise.
Old Mar 21, 2006 | 01:02 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">We use the JD2 Model 3 and the shop and it works great. </TD></TR></TABLE>
max bend is 180 right?
is there any small amount or crushing at that point?
Modified by dfoxengr at 9:39 PM 3/25/2006
Old Mar 21, 2006 | 01:16 PM
twilightprotege's Avatar
tony1 - that's the bender i'm going to buy. looks the goods, esp for rollcage fabrication.
i was kind of hoping that it would work on exhaust piping with the use of a mandrel, but they havent got back to me
Old Mar 21, 2006 | 01:23 PM
dfoxengr's Avatar
Default Re: (twilightprotege)
it wouldnt work. real madrel benders are over ~20K for a decent one.
Old Mar 21, 2006 | 03:16 PM
but all a "mandrel" bender is really doing is using a mandrel inside of the pipe when it's being bent as far as i know... those expensive ones are just automated so the mandrel stays in the right position all the time
Old Mar 25, 2006 | 03:04 PM
dfoxengr's Avatar
Default Re: tube/pipe bender (dfoxengr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">max bend is 180 right?
is there any small amount or crushing at that point</TD></TR></TABLE>
Modified by dfoxengr at 9:38 PM 3/25/2006
TVT_DESIGN
Welding / Fabrication
Jan 2, 2008 02:24 PM
Running925
May 26, 2006 08:43 AM
bostoncal
Nov 23, 2005 02:44 PM
DIY_Racing
Apr 27, 2005 08:28 AM
IN VTEC
Mar 8, 2004 07:03 PM
