Valve Covers
Old Feb 5, 2005 | 03:34 PM
Shizznaz's Avatar
Default Valve Covers
I found a Mugen Valve Cover that im interested in buying. Is this something I can install myself? If so, what other products will I need to buy like oil or gaskets etc. to do it?
Old Feb 5, 2005 | 04:48 PM
Shizznaz's Avatar
Default Re: Valve Covers (Shizznaz)
bump =/
Old Feb 5, 2005 | 05:08 PM
eda6's Avatar
Those are simple to install. Get a valve cover gasket set. Comes with valve cover gasket and 4 spark plug seals. Take a minute to clean up the oil on the head so it doesn't leak afterwards. Hondabond may be needed around the cam area. Torque the crown nuts to 7 ft.lbs
Old Feb 6, 2005 | 09:30 AM
PrettyLude's Avatar
Default Re: Valve Covers (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">Those are simple to install. Get a valve cover gasket set. Comes with valve cover gasket and 4 spark plug seals. Take a minute to clean up the oil on the head so it doesn't leak afterwards. Hondabond may be needed around the cam area. Torque the crown nuts to 7 ft.lbs</TD></TR></TABLE>
Old Feb 6, 2005 | 09:58 AM
Chase's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote"> Torque the crown nuts to 7 ft.lbs</TD></TR></TABLE>
This measurement is VERY important, you dont want to over torque it and break the stud. Or even worse break the cam cap(like i did )
Old Feb 6, 2005 | 02:44 PM
Do_Ster's Avatar
Default Re: Valve Covers (b16crxkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16crxkid &raquo;</TD></TR><TR><TD CLASS="quote">
This measurement is VERY important, you dont want to over torque it and break the stud. Or even worse break the cam cap(like i did )</TD></TR></TABLE>
yeah be very careful. those studs are like twigs.
iLovPhoKing
Jan 2, 2006 08:07 PM
fanta!
Jun 29, 2005 03:52 PM
NoLipRacen
Jan 23, 2004 12:32 PM
PearlWhiteAccord
Jan 8, 2004 01:13 PM
civic91
Dec 31, 2003 07:44 AM
