Can you say dirty IACV??
Old Feb 5, 2005 | 03:24 PM
.BigSexy's Avatar
most hood white kid
Default Can you say dirty IACV??
Well I was really bored today, so I decided to clean my IACV, and man was I in shock....here is what I found...
Before:
and after cleaning:
let me know what you think
Old Feb 5, 2005 | 03:36 PM
Hawkze_2.3's Avatar
Default Re: Can you say dirty IACV?? (egcoupe94)
Yyyyeeeaaahhhh.....that's what happens when you clean it. Is it idling better now?
Old Feb 5, 2005 | 03:38 PM
jlacoy82's Avatar
71.192.16.183
Default Re: Can you say dirty IACV?? (Hawkze_2.3)
Yucky. What'd you clean it with? A pressure washer?
.BigSexy's Avatar
most hood white kid
well, not really, it is doing somewhat better, but not as much as I thought, I still have pretty rough idle, kind of sputters a bit
Old Feb 5, 2005 | 03:40 PM
.BigSexy's Avatar
most hood white kid
Default Re: Can you say dirty IACV?? (jlacoy82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">Yucky. What'd you clean it with? A pressure washer? </TD></TR></TABLE>
wraped the plug connector in a paper towel, secured it with a rubber band, used seafoam deep creep, and sparyed it very liberally, let it soak for a while, and voila
Old Feb 5, 2005 | 03:55 PM
4DRPIMPIN's Avatar
I hope that sea foam cleaner didn't ruin that gasket on it. From the picture it doesn't look like it's damaged. I'd check it just for peace of mine.
Old Feb 5, 2005 | 04:01 PM
.BigSexy's Avatar
most hood white kid
Default Re: (4DRPIMPIN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DRPIMPIN &raquo;</TD></TR><TR><TD CLASS="quote">I hope that sea foam cleaner didn't ruin that gasket on it. From the picture it doesn't look like it's damaged. I'd check it just for peace of mine.</TD></TR></TABLE>
how would it ruin it?
Old Feb 5, 2005 | 08:22 PM
.BigSexy's Avatar
most hood white kid
bump
Old Feb 5, 2005 | 08:24 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (egcoupe94)
Usually idle problems on our cars arise because the plunger inside the cylinder of the IACV gets fucked up and loose and the air just breezes right past it in huge gusts. The screen just keeps debris out...it doesn't do a whole lot as far as changing the idle characteristics.
Old Feb 5, 2005 | 08:38 PM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">how would it ruin it?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote"> the plunger inside the cylinder of the IACV gets fucked up and loose and the air just breezes right past it in huge gusts. </TD></TR></TABLE>
The internal parts of the IACV are what makes it work. If they're not sealing properly, there won't be an improvement with a cleaning. When one is bad, I've never seen anything work besides replacement or a rebuild; and I don't even know if there is a rebuild kit for Hondas.
Old Feb 5, 2005 | 08:56 PM
.BigSexy's Avatar
most hood white kid
arent new ones like 200 bucks??
Old Feb 5, 2005 | 09:01 PM
Good ol' Screwtape's Avatar
Multi-paradigm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">arent new ones like 200 bucks??</TD></TR></TABLE>
$10.00 -used- eBay.
http://search.ebay.com/IACV_W0QQfkrZ1QQfromZR8
new parts are overrated.
Old Feb 5, 2005 | 09:12 PM
.BigSexy's Avatar
most hood white kid
but how would I know if it were a good IACV with good internal parts to make my idle alot smoother? it still kind of sputters when at idle, and it annoys the **** out of me
Old Feb 5, 2005 | 09:58 PM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">but how would I know if it were a good IACV with good internal parts to make my idle alot smoother? it still kind of sputters when at idle, and it annoys the **** out of me</TD></TR></TABLE>
Are you sure you don't have any vacuum leaks though? While it's usually an IACV, a vac leak can cause idle problems too.
And, yes, the IACV is pretty pricey; but if you narrow it down to that, it's well worth it to fix the problem. For $10 or whatever a yard charges, you might want to try it first, you may save some bucks.
Old Feb 5, 2005 | 10:04 PM
McNizzle's Avatar
usually you will get an engine light if the interals are bad i believe..... (code 14)
as far as gettin one on ebay for about $10,that is true in a way, but they say its like $20 for shipping or some outrageous amount. I got an extra one layin around for $20shipped from when i was trying to solve my idle problem if interested I also have a FITV as well.
Old Feb 5, 2005 | 10:09 PM
.BigSexy's Avatar
most hood white kid
Default Re: (EX_AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">
not a vacuum leak, it would cause the idle to be more of a violent idle like a 200 RPM jump, this just has an 800 RPM jump or so, so i wouldnt say a vaccumm, <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris M &raquo;</TD></TR><TR><TD CLASS="quote">
as far as gettin one on ebay for about $10,that is true in a way, but they say its like $20 for shipping or some outrageous amount. I got an extra one layin around for $20shipped from when i was trying to solve my idle problem if interested I also have a FITV as well. </TD></TR></TABLE>
i might be interested..PM me, what is the FITV?
Old Feb 5, 2005 | 10:20 PM
McNizzle's Avatar
FITV is the Fast Idle Thermo Valve...its located under the throttlebody and controls cold idle start up. It has a coolant line running to it.
Old Feb 5, 2005 | 10:22 PM
McNizzle's Avatar
Default Re: (Chris M)
is your idle rough all the time or only when u start it up or only after it warms up? if its just kind of rough and not fluctuating its most likely not the FITV or IACV or a vaccum leak. It could be somethin like a o2sensor goin bad, bad distributor/dist coil/rotor, plugs or plug wires. have u done a tune up recently?
Old Feb 5, 2005 | 11:03 PM
AllmtrSlut's Avatar
Old Feb 5, 2005 | 11:58 PM
Mike K's Avatar
9 times out of 10, a dirty IACV will not cause a rough idle. you have other issues if you have idle fluctuation, etc.
Old Feb 6, 2005 | 12:13 AM
showtymers619's Avatar
* B A N N E D *
Default Re: (Mike K)
fitv
Old Feb 6, 2005 | 02:13 AM
menkio's Avatar
Default Re: (ShowTymers619)
steam clean owns all
Old Feb 6, 2005 | 04:52 AM
Junkie Si's Avatar
Default Re: (menkio)
wasup...dang...my iacv looked just likes yours and after i cleaned it with some seafoam the car ran really nice...fixed my problems...hope everything works out for you
Old Feb 6, 2005 | 11:25 AM
.BigSexy's Avatar
most hood white kid
it is rough all the time, no i have not done a tune up lately, i really need one, I was pretty productive this weekend though, cleaned my IACV, seafoamed, coolant flush, oil change, and deep creep on my IM and TB, also i cleaned my k&n air filter, man was it gross. but my idle is still not smoothe like i want it to be. I changed the plug wires back in September, i do neede new plugs, o2 sensor is about a year old. rebuilt distributor was put on a year ago this month, so im thinking bad IACV, but i am really lost. It isn't that bad, it just really bugs me, it idles at about 400 RPM when warm, and it sputters, doesnt fluctuate very much, im gonna change plugs tomorrow, ill let ya know what happens.
Highlifer
Aug 4, 2007 08:12 PM
ill roller
Mar 30, 2007 10:42 PM
00ekcoupe
Oct 28, 2005 09:54 PM
imported204
Feb 2, 2004 08:00 PM
