Help with LS fuel rail on AEBS manifold.
Old Feb 5, 2005 | 01:23 PM
crexer's Avatar
Default Help with LS fuel rail on AEBS manifold.
Got a 99 ls fuel rail to use on my aebs manifold and im having some trouble with the crush washer placement. Its spraying out fuel from the fuel rail end whenever I prime the fuel pump. Also it seems as if my stock DX fuel line might be a bit small for this rail. It worked fine for the obd0 b16 fuel rail. The ls rail I got had a washer with like 4 teeth on it that I removed and lost and I tried using thse brass crush washers and it still sprays out. What should I do? Order a fuel line for a 94 del sol vtec???
Old Feb 5, 2005 | 02:31 PM
eda6's Avatar
Default Re: Help with LS fuel rail on AEBS manifold. (crexer)
Did you install the parts onto the rail in this order: fuel line, washer, 22mm nut?
If so, try flipping the crush washer around. If it still leaks get the correct parts from the dealer.
Old Feb 5, 2005 | 02:36 PM
crexer's Avatar
Default Re: Help with LS fuel rail on AEBS manifold. (eda6)
it dosent just leak it sprays
Old Feb 5, 2005 | 03:47 PM
black90si's Avatar
I would check the washers. I have the same intake and im using a ls fuel rail and a stock crx fuel line and it works fine.
Old Apr 15, 2013 | 12:04 AM
Corksil's Avatar
Where can I find the 22mm nut that connects the fuel line to the fuel rail?
Yes, bumping old threads.
c95gsr
Oct 9, 2009 08:50 AM
johnwohl
Feb 10, 2008 11:07 AM
HpRevolution
May 23, 2007 09:42 AM
sohc1200cc
Nov 3, 2006 10:02 AM
