what trannys are these?
Old Feb 5, 2005 | 01:02 PM
alexsracing's Avatar
Default what trannys are these?
L3-2582173 ? 1
L3-2411473 ? 2
L3-2007850 ? 3
from crx's
Old Feb 5, 2005 | 04:02 PM
ServiceAdvisor's Avatar
No way to tell from those SERIAL #s. Give us the code that reads "PLA-000XX" Something of that nature. That is the easiest way to distinguish a L3 tranny. - Darrell
Old Feb 6, 2005 | 08:25 AM
where on the tranny are thoes codes? PLA000xx?
Old Feb 6, 2005 | 09:22 AM
bump
Old Feb 6, 2005 | 10:51 AM
anybody?
Old Feb 6, 2005 | 12:11 PM
bump, anyone know how to tell if its an si tranny?
Old Feb 7, 2005 | 09:50 AM
bump
Old Feb 7, 2005 | 11:32 AM
Gearspeed-Performance's Avatar
Default Re: (alexsracing)
They should be in the cast near the axle hole on the Main case(outer)
Old Feb 7, 2005 | 01:12 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (GearSpeedEF9)
Any idea what a PL3-A000 would be?
Old Feb 7, 2005 | 02:07 PM
Default Re: (88DXCRX)
A000 has a white speedo. More than likely not an Si. Counter and ring gear will tell a tale of what it is.
Old Feb 9, 2005 | 08:39 AM
pl3-a100
pl3-a000
Old Feb 9, 2005 | 08:56 AM
ssl2k's Avatar
take the case off and count the number of teeth on the ring gear and counter shaft
that will tell you if it is a hf/dx/zc/ex/si tranny
hf had like a 2.x ish fd?
dx/zc were 3.88
ex had 4.058
si had a 4.25
then count the number of spines on the input shaft, that'll tell ya the year
if you figure out that it has a 3.88 final drive, chances are more than likely it is a dx tranny, but try putting a regular d series axle into the differental hole, and if it is too small, you got yourself a zc tranny (highly doubt it)
or if you dont feel like doing that, swpa each of them into your car, and record your RPM and MPH for
1st gear @ 15mph
2nd gear @ 25mph
3rd gear @ 35,45,55 mph
4th gear @ 45, 55 and 65 mph
5th gear @ 55, 65, 75 and 85
that should give you more than enough data to figure out which gear ratios you have + what tranny it is
Old Feb 9, 2005 | 09:02 AM
88DXCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GearSpeedEF9 &raquo;</TD></TR><TR><TD CLASS="quote">More than likely not an Si.</TD></TR></TABLE>
reL3-A000
That is what I figured..It came out of an '88 HF
that someone {probably a junkyard} had put a D16a6 into,
But they used the intake manifold,exhaust,ECU
and I guess also the transmission from the HF...
Old Feb 9, 2005 | 01:33 PM
I have a 88 hf says PL3-A000
i need to know what a PL3-A100 is I have 2
Old Feb 9, 2005 | 02:00 PM
Open it up and count the teeth....that is the only way to find out exactly what you have.
Old Feb 9, 2005 | 02:30 PM
ssl2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GearSpeedEF9 &raquo;</TD></TR><TR><TD CLASS="quote">Open it up and count the teeth....that is the only way to find out exactly what you have.</TD></TR></TABLE>
Or swap them and record mph/rpm's and go from there....
Old Feb 10, 2005 | 05:43 AM
so in other words you don't know what the A100 tranny is
Old Feb 10, 2005 | 07:29 AM
Welcome to my world!! You have to open it up to find out. It is not an Si transmission though.
Old Feb 12, 2005 | 06:36 AM
my friends si crx says A100
Old Feb 12, 2005 | 09:48 AM
DaMmniTz's Avatar
Default Re: what trannys are these? (alexsracing)
instead of looking for your serial and don't know what is was, Why didn't you just ask for the serial of the Si tranny? Make it easy and simple.
Si Tranny is PL3/3000 cast into the casing just above the fill plug.
PL3-A000 is your stock hf tranny.
bigginsUT
Jan 4, 2007 12:43 AM
jeezyskillz
Nov 7, 2006 05:53 PM
crxblues
May 20, 2006 09:43 AM
sloweredcivic
Apr 27, 2004 07:20 AM
ViperRedCRX
Nov 11, 2003 07:05 AM
