89 si for trade only !!!!!!!!
ok here it is i have a white 89 si with a gsr swap im thinking of trading for a 5g civic si plus some cash unless you got extras on it or any 6g hatch as for ok the body is ok had a bent fender i replaced it but needs paint has a small dent in the rear quarted but its nothing that is major it has all clear corners straight red tails and black midwing interior is from a 94 integra blck cloth nice! has white trimming in the interior plus indiglos black monster tach and carbon fiber water-temp and oil pressuer also has factory honda cd radio
suspension:
brand new kyb struts and apc coilovers
with spoon look-alikes with kuhmo tires very low mileage
motor:
94 gs-r obd 1
act heavyduty street and strip clutch
full msd setup(6al,blaster coil,and cap)
skunk2 type r style intake
ractive cold air
brand new interstate battery
skunk 2 cam gears
aem fuel rail
b&m fuel reg plus gauge
jdm type r valve cover
denso iridium plugs
full focuz exhuast
place racing mounts
plus place racing wiring harness wich alows you to use a gsr ecu
motor has had all gaskets changed so has the water pump oil pump timing belt tensioner the whole nine yards motor was also cleaned and painted its imaculate this car has yet to be even turned on from the swap as i am still waiting for the wiring harness this car is ready to go
_______
suspension:
motor:
94 gs-r obd 1
ractive cold air
skunk 2 cam gears
aem fuel rail
denso iridium plugs
full focuz exhuast
place racing mounts
_______
