will 90-91 CRX si rims clear EX 10.2" brakes?
Old Feb 5, 2005 | 11:30 AM
GSRCRXsi's Avatar
Default will 90-91 CRX si rims clear EX 10.2" brakes?
i searched and did indeed find many topics on this but the answers are inconsistent. its 50/50. some people say yes, some people say no. i need a definite answer here. will the 10.2" brakes Civic EX brakes clear 90-91 CRX Si 14" alloy rims?
Old Feb 5, 2005 | 11:40 AM
d16a6crx's Avatar
Default Re: will 90-91 CRX si rims clear EX 10.2" brakes? (GSRCRXsi)
yes
ElementMotor's Avatar
Yes, I am running that set up right now. Had to grind away a little from the inside of the rims though, but its not a big deal at all.
Old Feb 5, 2005 | 06:10 PM
GSRCRXsi's Avatar
Default Re: will 90-91 CRX si rims clear EX 10.2" brakes? (EF8 ownz U)
so modification is necessary? and why would you grind from the rim? why not just take it off the caliper?
Old Feb 6, 2005 | 11:43 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRCRXsi &raquo;</TD></TR><TR><TD CLASS="quote">so modification is necessary? and why would you grind from the rim? why not just take it off the caliper?</TD></TR></TABLE>
The person I got the car from allready had done it, so I wasn't complaining. Whatever works. Either way you do it, doesn't really matter, as long as the wheel spins...
Old Feb 6, 2005 | 12:51 PM
jdmEFsedan's Avatar
i've got crx si wheels on my EF sedan EX. I used a spacer (eventhought I hear it's not safe) in order for it to clear. so far, no bearing problems. we'll see though.
i would grind the caliper. in my opinion, it's easier.
Old Feb 6, 2005 | 02:06 PM
stickershop.ca's Avatar
Default Re: will 90-91 CRX si rims clear EX 10.2" brakes? (EF_VTEC)
Did this swap 2 days ago. Found out the hard way, as my car turned into a mobile lathe during the test drive. Modification is necessary, but it's not a huge mod. From what I can tell, only the raised sections on the back of the rims need to be ground down flush with the rest of the back of the rim. You could also grind the calipers...not sure how safe that is though.
leadphut
Honda Civic (2006 - 2015)
Jun 3, 2007 08:35 PM
vtecn8ive
Mar 17, 2006 06:27 PM
mbsi
Mar 23, 2005 06:53 AM
crxgurlllll
Aug 8, 2002 05:45 PM
customx_
Dec 10, 2001 08:31 PM
