Best place to buy JDM ITR Valvetrain online?
I've checked the archive, jhpusa, and inlinefour.com
inlinefour sells the outer springs, and intake valves, but nothing else.
I was curious where the best place to get ALL ITR valvetrain components online would be. Thanks for the help itr guys!!!
EDIT: Added ITR on 3rd line.
EDIT #2: removed JDM from line 3
EDIT #3: fixed one line up.
Modified by projectegr at 12:46 PM 2/5/2005
Modified by projectegr at 1:15 PM 2/5/2005
Modified by projectegr at 1:16 PM 2/5/2005
yo. i know this is completely off topic, but i couldnt get an answer anywhere and can only seem to post in this page..but, how do you get off restricted status and be able to use the ht account to the full potential(i.e. pm, replies, etc)
thanks and sorry for goin off topic on your thread
Access Level Normal User
Permission Level Unrestricted User
Full Name leon gallego
Email Address emagdnimlg@sbcglobal.net
Location milpitas ca usa
Age 22
AIM Name lgsarcasticlg
You are not restricted.
Just change your avatar by clicking on my profile at the top.
Age 22
Here's one place from a recent post:
http://www.acuraoemparts.com/delray/jsp/home.jsp
There are a couple more on-line OEM retailers, but it's your job to find them.
Personally, I'd call Len and order whatever parts you'd need.
https://honda-tech.com/zero...=4157
Check his sig, he a parts manager at Baranco Acura and might even give you a discount if you mention H-T.
You want to change the valve train to something else eh? I'll be the stupid guy....anyone know the difference? I was under the impression that the JDM heads/parts and USDM heads/parts were the same. It was the pistons that were slightly different yeilding a lower compression ratio compared to the JDM models.
If your looking for something a bit spunkier than JDM (if it is different) I'd recommend Import Builders or Rocket Motorsports. You can get the retainers/springs/cams from both of those companies.
At any rate, good luck in your search.
Aloha,
Brandon
Aloha,
Brandon
luuisss
Jan 18, 2012 11:25 AM
Jon D
Apr 19, 2007 07:34 AM
