O where O where does this wire go...
Old Feb 5, 2005 | 09:31 AM
untitled's Avatar
Default O where O where does this wire go...
The hatch was recently broken into, with all of the audio componenets being stolen out of it. When the perpetrator was effin around under the driverside dash area they rip around a bunch of wires, since then i have not been able to get the car to start. The door indicator beep isnt there, the fuel pump wont prime and there is no spark. This led me to the main relay. I hardwired the fuel pump to make sure that it still worked and it did. So i switched main relays with one i know works, that didnt help the situation. So i was screwin around under there and noticed 2 wires that are close to 16ga. One is blue with green stripe and one is gray with black black stripe, each has a single female connector that is similar to the connector that would go into the back of a plug on an ECU. Each wire leads up underneath the furthermost part of the driver side dash and i can track them. I cannot see any places where these wires plug into and i have a feeling that they are the culprit behind having no spark or no fuel pump.
Blah!1, its frustrating not being able to figure this out on my own!!
Heres a pic to get some replies:
Old Feb 5, 2005 | 10:19 AM
dogfood's Avatar
Default Re: O where O where does this wire go... (untitled)
check your fuses, especially the main ignition fuse, when the moron thief was ripping out wires he may have shorted a couple together, Since nothing is coming on it sounds like the main ignition fuse
hatchinprogress's Avatar
well i hope you fix the problem before your car looks like the one in the pic! i had the same thing happen to me (a theif stole my radio) and some exposed wires caused a spark and shorted alot of stuff, i had help but we just followed the wires(like you did) made sure everything was ok and then replaced fuse's and now it SEEMS to be ok(i got my fingers crossed) ******* thieves
Old Feb 5, 2005 | 10:26 AM
untitled's Avatar
Default Re: O where O where does this wire go... (dogfood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dogfood &raquo;</TD></TR><TR><TD CLASS="quote">check your fuses, especially the main ignition fuse, when the moron thief was ripping out wires he may have shorted a couple together, Since nothing is coming on it sounds like the main ignition fuse</TD></TR></TABLE>
Welll the wierd thing about is that thr car will turn over and everything, everything works except fuel and spark and the beeping thing when the door is open. BLAH...
going out to check fuses again...
Old Feb 5, 2005 | 10:29 AM
dogfood's Avatar
thats weird, the second guy is right, I guess a wiring diagram and many cups of coffee is the only way then, unless any one else has a suggestion
Old Feb 5, 2005 | 10:33 AM
untitled's Avatar
Well theres been many coffee cups for the past month, BUT
Theres been a new development:
I found the plug that the wires went to by using the online helms (link found in CRX/Civic FAQ) and i plugged them in, now i just have to get the battery charged to see if that was infact the prob.
ill let ya know.
Old Feb 5, 2005 | 10:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untitled &raquo;</TD></TR><TR><TD CLASS="quote">Well theres been many coffee cups for the past month, BUT
ill let ya know. </TD></TR></TABLE> glad you found a new lead
Old Feb 5, 2005 | 11:03 AM
untitled's Avatar
Default Re: O where O where does this wire go... (hatchinprogress)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote"> glad you found a new lead </TD></TR></TABLE>
That wasnt it, i am testin gthe ECU with one that i know works now.
mr darcko
11
Jun 20, 2012 08:25 AM
hatchz6
Dec 30, 2009 05:39 AM
on-site ej1
Apr 3, 2009 09:30 AM
Reaper369
Jul 3, 2007 12:03 PM
DarkDragon
Jun 12, 2005 12:03 PM
