HELP, key wont turn in ignition! car is stranded
Old Feb 5, 2005 | 08:46 AM
drew2's Avatar
Default HELP, key wont turn in ignition! car is stranded
car was parked. steering locked and key wouldn't turn. usually just wiggle the steering and key turns. couldn't get it to do anything. finally broke the steering free so wheel turns now, key still doesn't turn tho. What do i do??
Old Feb 5, 2005 | 11:18 AM
hybridem1's Avatar
Default Re: HELP, key wont turn in ignition! car is stranded (drew2)
try to a new key cut then if that doesn't work you need a new ign. cylinder.
Old Feb 5, 2005 | 02:45 PM
PrettyLude's Avatar
start taking apart the steering column and take apart the ignition switch, after that you can take it with a screwdriver
try and get a new key cut, or the mechanical part of ur ignition system went bad
Old Feb 13, 2005 | 01:00 PM
Timedatombomb's Avatar
Default Re: (PrettyLude)
my car is havin the same problem I stick my key in go and turn and that **** will not turn for **** its just like not turning at all it stays on OFF completely its pissin me of ) but is it the ign cylinder is that the name for it??? Can u link me to a good deal to buy one... are they hard to install if I have the manuel too the car??? And does it make a diffrence if i have a auto or manuel.. Cuz I have a automatic.
Old Feb 13, 2005 | 03:00 PM
PrettyLude's Avatar
its not that hard to install if you have a manual, just have to drop the steering column covers.
go to hondaautomotiveparts.com they have good prices on it
Old Feb 13, 2005 | 03:23 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">its not that hard to install if you have a manual, just have to drop the steering column covers.
go to hondaautomotiveparts.com they have good prices on it</TD></TR></TABLE>
also the ignition switch itself is held by 2 bolts and remove the 5-pin & 7-pin connector. that's it.
safedriver
May 25, 2012 02:48 AM
loki2010
Dec 30, 2010 07:18 AM
nascar8309
Honda Civic (2001 - 2005)
Nov 19, 2010 06:22 AM
Hazem
15
Dec 16, 2004 01:54 PM
