So you bought a EDM PM7 ecu...
Ok, here's the story a while back I bought an ECU for the ZC swap I had hoped to do. Finally when I actually get the swap in I find out that the ECU os an EDM and I have a code 11. Apparently a code 11 is for some sensor that isn't equipped in out USDM or JDM engines. Anyone know if I can maybe bypass the sensor in the ECU or maybe have it reprogrammed?
