Need ITR bearing and hub info
First of all, I did a search and could not find all the answers.
I have an ITR 5-lug conversion on my Civic but I'm not sure what year ITR it's from. All i know is that it bolts on to the the stock Civic axles with the 32mm nut. Apparently this is a 95-97 USDM ITR.
Now I need a front hub and bearing replacement and I need the OE part numbers for these items. All I have now is a bearing with part number 44300-S5A-004. Hopefully this fits any year ITR as I already have it in the freezer. Thank you all in advance.
Modified by L8apex at 1:33 AM 2/5/2005
006 44600-ST7-R00 HUB ASSY., FR. 2 1997 Acura INTEGRA 123.50 98.80
http://www.acuraparts247.com/s...ch=no
Thanks for the very helpful info sackdz! I seached that site and found the same part numbers for the hub and bearing for a 1997 and 2001 ITR. I've heard they are different and I'm still not sure which one I have or the correct part number that I need.
Yes with enough play in the bearing it will wobble around and destroy the hub shaft as well. Also, any moisture that gets in there will cause it to rust and corrode.
Modified by L8apex at 7:45 AM 2/5/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L8apex »</TD></TR><TR><TD CLASS="quote">Thanks for the very helpful info sackdz! I seached that site and found the same part numbers for the hub and bearing for a 1997 and 2001 ITR. </TD></TR></TABLE>
USDM (32mm nut) hubs are the same for 97/98/00/01.
JDM hubs/axles use a 36 mm nut.
Maybe that's what you might have heard.
That's probably what I heard because I know JDM ITRs were slightly different after 98, but USDM ITRs stayed mostly the same from 96-01 (excpet for not being sold in 99). Thanks again everyone for your help.
Redline96LX
Oct 19, 2005 03:19 PM
