engine rebuild kit
a rebuild kit wont be there dude...
check out http://www.rpmrons.com tehy have one, but i gotta be honest, these motors...b21a1 and b20a5 and teh JDM b20a (dont get it mixed up with the crv motor cause its nothing near the same) are only about 500-600 bucks, with the work to pull the motor get everything in there and all, its almost more efficent/cost effective to get a new motor with like 50K on it...
as for the kit, look for a "re ring" kit, its a full gasket set wiht rod bearings and piston rings...unless you want pistons and head work...
as for pistons...if you go that route, check out http://www.raceeng.com they sell the 81mm bore forged 10.5:1 comp and 9:1 comp for the b20a5...just a heads up
