2000 accord power window main switch...need help
Old Feb 4, 2005 | 06:38 PM
norcim's Avatar
Default 2000 accord power window main switch...need help
I have a camery 98 with a broken main window switch. The circuits are fine but one of the buttons are broken. I don't want to replace the whole then for $250 so I want to try and replace just the shell.
The newer accords have a similar window buttons (pull up and push down) so I was hoping to get some feedback on solving the problem with my Camery from those who had a broken button on a Honda.
Can anyone tell me if they were successfully able to change a single buton from a switch unit on a Honda2000 or Camery98? Or do you have to replace the entire shell with all the buttons attached?
Old Feb 5, 2005 | 05:13 AM
Turbowa's Avatar
Default Re: 2000 accord power window main switch...need help (norcim)
You have to replace the whole unit. The button isn't what wears out its the electrical portion inside the main unit.
Old Feb 5, 2005 | 03:05 PM
norcim's Avatar
Default Re: 2000 accord power window main switch...need help (Turbowa)
In this case, the plastic button was physically broken. I was able to take it off and the sliding mechanism on the circuit board is working fine. I can use a screwdriver to slide it back and forth and the window works.
I'm just not sure if the individual buttons can be replaced or if they are made with the top shell.
Czapsiu
Jun 9, 2018 07:54 AM
Hawaii Da9
Jan 16, 2012 06:19 AM
hecihec
Oct 26, 2010 01:17 AM
Ttlogan
May 25, 2009 10:55 AM
Siegfried
Nov 25, 2004 12:13 AM
