B16 speedometer question
ok, so my B16 is now in the car. Im in the process of bolting everything in but ill be damned if i can find the place to plug in the speedometer cable. It is a Y1 w/ lsd if it matters. The only place i can think of it going there is a metal box thingy with 3 10mm screws holding it on and a sensor plug of some kind. I took it off and tried to plug it in but to no avail. Im totally stumped and any info would be great and a pic would be great.
TIA, adam
TIA, adam
if it's a cable tranny. On the tranny you'll see a thing with two vetns coming out of it. Take out the cut cable and put it in, but make sure you hold on to the CLASP to keep the cable in.
Now when you say the old one you are refering to the speedometer cable right? If so it will not plug into the Y1 once i remove that metal thing with a clip. Or is there there another piece on my old tranny that needs to be pluged in. If so my old one has a 10 mm bolt attached to where it pluged in but once i removed that it is broken off from where the speedometer cable pluged in. hope im making sense.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">does the sensor look anything like this one?
it sould look like this..
</TD></TR></TABLE>it sould look like this..
From: I told you to wait in the truck in Texas, United States
look at the first and second pic..find the black boot..
[Looks like a top-hat]
The scrappers usually just cut the cable..
(Otherwise you have the wrong type of sending unit)
OK here is a better pic of what im looing at...
Now my speedometer cable will not plug into this so i am assuming that i need to get a new sending unit. How do i go about this? Dealership but if so what do i ask for the correct part because i really dont know what im looking for.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XtraFastCRX »</TD></TR><TR><TD CLASS="quote">that is the right spot just get your old one from your other tranny and put it in..</TD></TR></TABLE>
Have heard that will work...
swint2007
Apr 3, 2010 11:14 AM
