Honda Injector Question?
Old Feb 4, 2005 | 04:58 PM
Greasemonkey's Avatar
Default Honda Injector Question?
I have an 96 LS OBD2 Motor and my injector aren't spraying correctly so it's giving me CEL. I have some injector from a DX motor and I was wondering if I can use it.
I know the LS injector spray at 240cc so I am wondering how much CC's the DX injector are spraying.
Thanks for the help.
Old Feb 4, 2005 | 08:59 PM
eda6's Avatar
Default Re: Honda Injector Question? (Greasemonkey)
dx injectors are also 240cc's
Ohm out the injectors with an ohmmeter...if the coil resistance is 10-13 ohms install them. If resistance is 1.5-2.5 ohms use a resistor box with them. If the dx injectors are pre-obd or obd1 you'll need new injector clips.
Old Feb 5, 2005 | 12:11 PM
Is this the same for 99 SI injector
Old Feb 5, 2005 | 02:11 PM
eda6's Avatar
Default Re: Honda Injector Question? (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greasemonkey &raquo;</TD></TR><TR><TD CLASS="quote">Is this the same for 99 SI injector</TD></TR></TABLE>
99 si injectors are saturated. Resistance should be 10-13 ohms.
They will work.
Old Feb 13, 2005 | 06:43 PM
Thanks for you help
manuel3655
Nov 6, 2006 03:45 PM
SiR99
May 29, 2006 09:57 PM
Panoply
Jul 19, 2005 01:37 PM
Mr.Death
Jan 30, 2005 08:23 AM
