my intercooler piping custom made by me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stan D »</TD></TR><TR><TD CLASS="quote">shiny...
did you run a bead on the ends?
stan</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stan D »</TD></TR><TR><TD CLASS="quote">hairspray the ends when putting the connectors on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speeddave »</TD></TR><TR><TD CLASS="quote">just weld 4 bumps on the ends of the pipes, a bump each quarter of the pipe, super easy to do. easier than a full bead.</TD></TR></TABLE>
Since when do you need those things for running 10psi?
Ever try hose clamps that are tight?
i'm trying to figure out where i can get a bead rolled onto some of my IC piping... i found a tool that can do it but it's like 400$ and only goes up to 2" piping i believe.
why bother for 10psi? cheap insurance that i wont be driving on the highway at night and have a charge pipe come off!! ever try to do something to your car on the side of a highway in NY??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nuckingfuts »</TD></TR><TR><TD CLASS="quote">i'm trying to figure out where i can get a bead rolled onto some of my IC piping... i found a tool that can do it but it's like 400$ and only goes up to 2" piping i believe.
I have changed a headgasket on the side of the freeway before. i-53 for what it matters.
not sure if it compares to new york status but still there were plenty of ****** cars.
Don't waste the money on a bead roller you could get away with using a $85 fluxcore welder..
if you wanna be all baller use alum charge pipes, weld everything except off of the turbo, and then at the tb.
</TD></TR></TABLE>I have changed a headgasket on the side of the freeway before. i-53 for what it matters.
got any pics yet of it installed. also. since you based that on your b18a the b16 should be the same. how much you charging?
