gsr hub pull
Old Feb 4, 2005 | 12:44 PM
ez_steezy's Avatar
Default gsr hub pull
i was woundering if there is a key need in pulling the wheel hub or i could just do it w/ 1 1/4 socket any help would be great
Old Feb 4, 2005 | 02:06 PM
IN VTEC's Avatar
Default Re: gsr hub pull (ez_steezy)
You remove the 32mm axle nut and then use a slide hammer w/ a FWD axle puller from Autozone to yank the hub. It takes quite a bit of banging to completely remove the hub from the bearing since they're interference fit together.
Old Feb 5, 2005 | 03:19 PM
ez_steezy's Avatar
Default Re: gsr hub pull (IN VTEC)
thx
truesleeper
Apr 14, 2005 10:58 AM
typeeg
Jul 20, 2004 04:47 PM
integ u
Apr 25, 2004 12:37 PM
RicedREX
Feb 26, 2004 05:33 PM
