ZC Compression maxxxxxx..... HELP
What is the most compression that I can run (piston wise), and still be able to run 8-12 Lbs. of boost on my zc????? In process of cutting head and boring out block and are not sure what compression pistons to use to give max Hp. I can cut the head after pistons are bought to make up for the difference to give me max comp @ 12Lbs.. Thanks...
hatchinprogress
Nov 23, 2005 11:27 AM
redzcstandardhatch
14
Apr 30, 2003 11:42 AM
