ls vtec blown
Old Feb 4, 2005 | 12:05 PM
hybridpatient95's Avatar
Default ls vtec blown
friend of mine blew his ls vtec because of a rod bearing and he would like to know if he could just take out the pistons from the bottom without taking ouf the head.. it seems harder but he's had lots of trouble with oil leaks whenever he took of the head and put it back on... he doesnt wanna go through that again thanks guys
Old Feb 4, 2005 | 12:59 PM
doood's Avatar
been there done that
Default Re: ls vtec blown (frankenfiend 04)
if you try to take it out from the bottom you'll also need to take the crank out. much easier by removing the head.
Old Feb 4, 2005 | 03:07 PM
SkRiBLaH's Avatar
Default Re: ls vtec blown (stoned ****)
you can not take the pistons out from the bottom. you MUST pull the head.
Old Feb 4, 2005 | 03:12 PM
JoeB18R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stoned **** &raquo;</TD></TR><TR><TD CLASS="quote">if you try to take it out from the bottom you'll also need to take the crank out.</TD></TR></TABLE>
bwhahahahaha! id like to see that.
Old Feb 4, 2005 | 03:17 PM
xtrac1's Avatar
rookn00b
Gotta pull the head off...
Heres an old thread:
https://honda-tech.com/zero...age=1
Old Feb 4, 2005 | 07:13 PM
doood's Avatar
Default Re: ls vtec blown (JoeB18R)
yea your right. i wasnt thinking right.
Old Feb 4, 2005 | 07:39 PM
ExospeedAMcrx's Avatar
come on guys, do it right the first time. I assume you are redoing the block wihtout doing the machining? since you are doing it all while the block is in the car.
the best way to build it is machine it right. measure for proper clearances. new bearings that are to spec, check the crank if its damaged, if not micropolish it before measuring and assembly. and do a final bore/hone on the cylinder walls so the pistons are good in there and the rings will seal.
oh ya, dont forget to upgrade to a GSR oil pump.
Old Feb 4, 2005 | 07:54 PM
boosted420a's Avatar
Default Re: (exospeedAMcrx)
"his friend" blew it up...right..
Old Feb 4, 2005 | 07:59 PM
Default Re: (boosted420a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted420a &raquo;</TD></TR><TR><TD CLASS="quote">"his friend" blew it up...right..</TD></TR></TABLE>
Lol
Old Feb 4, 2005 | 08:21 PM
thanks guys
skiracer8148
Mar 31, 2007 06:47 PM
si0385.
Aug 27, 2006 07:00 AM
b20turboic
Nov 20, 2005 07:59 AM
wilkerson05
Jan 9, 2005 05:56 PM
lastpunkinline
15
Feb 11, 2004 11:04 AM
