F22A4 into 91 Accord LX
First of all, great forum I like the no nonsense approach. I have a 1991 Accord LX and the motor is tired, I just bought a 1990 Accord EX with 80K on and plan to swap the motor and trans into the 91? They both have 5 sp. Is there anything else that I need to swap other than the motor and trans? Also, I planned on basic maintenance (inspect/replace clutch, timing belt, water pump, oil pan gasket, and valve cover gasket) but is there anything else I should consider?
Thanks for any input you could offer.
ok ok. 7 years later. so i have a 91 accord lx wagon and wanted know if a 94 accord engine will fit in there with the oem trans. i already did some searches but noting really helpful.
This is a quote from Wiki. I even italicized the answer to your question for you just to make it clear:
"F22A
This engine series was used in the Honda Accord and Honda Prelude S. Aside from differences in tuning, these engines are substantially similar."
Yes! They do fit and work. Most if not all F-series parts are interchangeable.
You didn't search/read enough.
"F22A
"F22A
"F22A
so any F22a series engine will fit in my lx wagon and pass smog?
years from 90 to 95?
hometheaterman
Jun 27, 2008 06:01 AM
