SOHC ZC = d16a6 smog wise ????
Old Feb 4, 2005 | 10:07 AM
ZCHF's Avatar
Default SOHC ZC = d16a6 smog wise ????
Hello All,
My dohc zc blew up and now i need to get another motor. I was thinking about getting a sohc zc but I was unsure what i needed to put on it in order to make it a legal motor in cali. I heard that all you have to do is to put all of the cali smog stuff on but i was unsure if the motor had so already or not. I also have a hf motor that has all the smog stuff on it, could i use this or do i need to use d16a6 smog stuff. i was really unsure what i needed to pass in cali.
thanks guys
Old Feb 4, 2005 | 10:25 AM
PHOBIA's Avatar
as far as i know the zc is unsmogable because that paricular motor never came in any us base model car.just like the putting a tcr motor in your car,you cant go through emmisions with it because it was not available in the us only the itr was.
Old Feb 4, 2005 | 10:30 AM
Rywire's Avatar
Default Re: (PHOBIA)
you can smog a sohc zc in cali, just make it look exactly the same as a d16a6
Old Feb 4, 2005 | 10:35 AM
PHOBIA's Avatar
well, making it look the same and auctually getting it reffed are 2 differnt things.you may be able to fool a smog tech by switching valve covers but you will not fool a state referee"sp"
either way, what i would do if i was you is get a valve cover that doesnt say vtec on it and just go to a smog plass that is super busy or dirty.the only thing i could think of if you were trying to pass a ref test is tryinb to convert every thing to like a 87-89 integra.
Old Feb 4, 2005 | 10:47 AM
crxgator's Avatar
the valve covers are the same...externally they look the same except for the stamp...
Old Feb 4, 2005 | 10:57 AM
Rywire's Avatar
Default Re: (crxgator)
YOU CAN REF IT. Like i said, it has to look exactly the same as a usdm d16a6... that means the intake mani must have the same vac lines, exc...
See my writeup
http://www.norcalcrx.org/libra...shtml
Old Feb 4, 2005 | 12:09 PM
ZCHF's Avatar
Default Re: (droppedcrxsi)
thanks
the one i am going to buy doesnt say or have vtec, and nippon motors sells it as the d16a6 replacement. so the main thing that i have to change is the intake manifold????
Black-Ty [EG6]
Sep 4, 2007 08:38 PM
Chewy Built !
Jul 2, 2007 09:48 PM
civicdust
25
Mar 15, 2007 10:34 AM
1989CivicSi
17
Dec 14, 2005 08:24 AM
