Difficult Cold Start...
Old Feb 4, 2005 | 09:47 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Difficult Cold Start...
Here is the deal. I have an 89 CRX Si (stock w/ 175,000 miles). For the last few months I've had poor starts when the motor is not already warmed up. The motor cranks for 3+ seconds befor firing up. Once it starts, it stumbles for a moment, and then the revs jump up to the regular 1800+ for warm up. I've also noticed that when I blip the throttle after starting the revs somtimes actually drop when the pedal is pressed (WTF?). This makes the car very hard to get moving from a stop because if feels like it wants to die when I let the clutch out at anything less than 2000 rpm. Also the car feels like its down on power below 3000 rpm.
Here is what I've already done:
Cycled fuel pump before start (sometimes twice)
Oil Change
Crapy Fram Filter
New Cap
New Rotor
New Plug Wires
New Plugs
New Fuel Filter
Set Ignition timing
Tried Sea Foam
Fully charged Battery
Crappy Checker Auto Parts Alternator (2 yrs old)
All that with no significant change. Any help would be greatly appreciated...
PS.. I live in Las Vegas, so the coldest it gets is 30 degrees.
Old Feb 4, 2005 | 09:49 AM
RCautoworks's Avatar
Default Re: Difficult Cold Start... (94eg!)
Have you tried cleaning your coolant sensor off ?
Old Feb 4, 2005 | 09:50 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Difficult Cold Start... (90blackcrx)
No sir.
That sounds like a place to start.
Anything else?
Old Feb 4, 2005 | 10:02 AM
CRX Toad's Avatar
Do you wait for the check engine light to go off? I know it sounds stupid but my wife's car if you don't let the fuel pump prime it will crank but not start. Just turn to acces and wait till engine light goes off them try to start it...its worth a shot.
Old Feb 4, 2005 | 10:11 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Difficult Cold Start... (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">Do you wait for the check engine light to go off?</TD></TR></TABLE>
Yes I do. And as I mentioned above, I sometimes try that twice, and it always starts the same.
Old Feb 9, 2005 | 03:32 PM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried cleaning your coolant sensor off ?</TD></TR></TABLE>
I have checked the restance of the Coolant sensor across the range of temperatrues, and it is right on target. The sensor is also receiving the proper 5.5 volts from the ECU.
Does anybody else have any insight into this problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">Here is the deal. I have an 89 CRX Si (stock w/ 175,000 miles). For the last few months I've had rough starts when the motor is not already warmed up. The motor cranks for 3+ seconds before firing up. Once it starts, it stumbles for a moment, and then the revs jump up to the regular 1800+ for warm up. I've also noticed that when I blip the throttle after starting, the revs somtimes actually drop when the pedal is pressed (WTF?). This makes the car very hard to get moving from a stop because it feels like it wants to die when I let the clutch out at anything less than 2000 rpm.
Oil Change
Crapy Fram Filter
New Cap
New Rotor
New Plug Wires
New Plugs
New Fuel Filter
Set Ignition timing
Tried Sea Foam
Checked for proper operation of the "coolant temperature sensor"
PS.. I live in Las Vegas, so the coldest it gets is 30 degrees.</TD></TR></TABLE>
Old Feb 9, 2005 | 03:39 PM
ssl2k's Avatar
Does it do anything weird once it is warmed up?
I'm assuming there are no check engine lights as you didn't mention any...correct?
Old Feb 9, 2005 | 04:59 PM
Super Chicken's Avatar
Check the actual fuel pressure when it does this. Put a fuel pressure gauge on it and see what it does when you start it up cold. If the pressure is low it could be a faulty regulator or fuel pump.
Old Feb 9, 2005 | 05:02 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (ssl2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ssl2k &raquo;</TD></TR><TR><TD CLASS="quote">Does it do anything weird once it is warmed up?
I'm assuming there are no check engine lights as you didn't mention any...correct?</TD></TR></TABLE>
No check engine light.
It drives fine when warm, but sometimes feels like its hesitating between 2000-3000 rpm (sudden slight loss of power after I shift). It doesn't do that everytime, but it does it quite a bit. If feels like i lightly lifted off the throttle right after i've up-shifted (let the clutch out completely), and then put it back down again (even though I do not).
Old Aug 15, 2007 | 02:01 PM
ek guy's Avatar
Default Re: (94eg!)
i hate to bump an old thred but this is the same thing my car is doing OP did you ever find the answer to your problem? if not does anyone else have any sugestions in what it might be. i have went threw and changed everything the OP has. any input would be great. thanks
homoaranea
11
Nov 10, 2013 04:58 AM
InTheZoneAC
May 9, 2012 05:12 PM
DehKillaBeezz
Jan 9, 2011 09:54 AM
vanisher
11
Oct 15, 2007 07:00 AM
barry1me
Feb 6, 2007 11:44 AM
