Specs on F22A
What is the difference in a JDM F22A and the USDM F22A1 SOHC VTEC motors? Is the compression ratio any higher? The reason i ask is because my friend has a F22A (not in his Accord) and is not sure how much hp it makes. Everytime we ask someone the answer ranges from 135hp to 150hp. Also he was thinking of boosting it. Any info would be appreciated.
If your looking for more info on those engines you may want to check out http://www.accordinglydone.com
check in the tech section
Well the horsepower differs between the F22A models.... say, F22A1: SOHC 16V 130 hp. The F22A6: SOHC 16V 140hp.
Now the differnce between F22A and F22B is that F22A is a SOHC Non-VTec and F22B is a DOHC VTec.
Unless I'm wrong, I believe this is right.
Caleb
Caleb
dipsetking
Nov 21, 2006 01:39 PM
4g4drb17
Oct 27, 2004 03:42 AM
